1Back to top Go down   Well Lookee here... Empty Well Lookee here... Tue Nov 07, 2017 7:04 pm
Be afraid.. etc. There will be another LunchboKs.
Took a trailer load of things back to Guyra yesterday and accidentally bought a bike along the way. affraid ( as one does)
Looks like an 84RT. 79,000km on the clock. Plenty of work to be done....including the building of a sidecar to go on it but I'm looking forward to the fun!Picking it up next week.
Well Lookee here... Img_6911
Well Lookee here... Img_6910
2Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 07, 2017 8:44 pm
Welkom back Sean    Cool
3Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 07, 2017 8:51 pm
Back to the dark side, with side serve of a side car...welKome back.
4Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 07, 2017 9:35 pm
So you couldn't shake the K pox Sean.
If you need hand ute ect, let me know.
5Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 07, 2017 9:41 pm
WelKome back to the Kluster Sean.
6Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 07, 2017 9:58 pm
Thanks for the friendly welKome bacK.
Craig, it's a hard addiction to beat. The Triumph remains a magnificent motorcycle in the modern sense and does some jobs exceptionally well, the lacK of a K bike however needed to be addressed. Thanks for the offer of help. It should fit on the box trailer and doesn't have far to go.
Sean
7Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 3:17 am
Saxon7 wrote:Be afraid.. etc. There will be another LunchboKs.
Glad to hear you getting back on the K so to speak .
Given my current ailments with shoulder and muscles from previous injury , there is a spare chair here. Be good to see it get a new home that kares.
Well done .
Well Lookee here... 10_x_110
8Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 3:40 am
Have been talking to Ed and it looks like I've already found a sidecar to fit!
9Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 4:20 am
well blow me down , that was quick sean ...
that bike has a 86 or later tank
wonder if the frame mounts for it line up as the 84 models don't have the mounts for the tank built on ? (more a flat bar across the frame I think )
but really shouldn't be too much of an issue
geez wish I could weld , may have a similar issue in the future myself
welcome back !!
10Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 4:35 am
Sold to the unassuming man in the corner . Thanks Sean . Glad to see it go to someone who can appreciate the worth of a K chair .
Can't wait to see the progress of it all.
The chair in question is a DJP original with a 10"inch Mini Cooper wheel , fitted with a handbrake to the chassis .
Meets all RMS requirements . All that is needed is a suitable subframe .
Might need a new tyre on that wheel also Sean.
Well Lookee here... 15711
Well Lookee here... 15511
Well Lookee here... 16711
Well Lookee here... 00410
11Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 5:02 am
Thanks Ed, it will be a beauty! Am looking forward to getting into the project and will bore everyone to death post progress reports as I go.
We're putting up a new shed in Guyra as well to house the steeds. Thinking of putting a little stove in there as well. Hehe.
Charlie yes it was quick! I got to talking to a bloke I know in Guyra and he has a lot of bikes sitting in his shed and I spied the K model sitting there.
How much do you want to sell me that bike for? I asked... and the talk began. As far as I know it's an all 84 model. Compliance plate says 7/84 anyway. He says it was parked with the keys in it and hasn't been ridden since... but as you say.. all will be revealed when I take possession of it. Needs plenty of work... though he swears he had it running really well but it has no fuel pressure. Put in a new fuel pump but that ahsn't fixed the problem... will need new o-rings in the injectors etc etc etc and maybe that return line piece in the tank renewing. The motor will have to come out of the frame anyway to paint the frame so it will get a good looking at.
I've had a small stick welder sitting in my shed for 2 years now and still haven't learnt to weld! Maybe Craig can teach me sometime.
12Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 5:15 am
hmm I can see a trip to Guyra coming up
giggles
that chair looks like most of the work is done sean
perhaps renew the rusted out bits
good win I recon
13Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 6:54 am
Charlie - a serious piece of advice if you're considering stick welding. Do not under any circumstances buy a cheap welder as you'll get frustrated with it very quickly. Buy an inverter welder; my current one is a TIG/arc setup and cost around AU$450 but you can weld sh!t to a blanket with it. Okay, maybe not quite that, but it will deal with 1mm 303-grade stainless with no problem at all. It just laughs at mild steel. I'm self-taught and one thing I have found utterly invaluable is before starting a job, take two bits of scrap of the same type of metal as you're about to weld and stick them together as a test piece. That way you know your amperage and material reaction before you start on the real job.
14Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 7:46 am
Dai wrote:Charlie - a serious piece of advice if you're considering stick welding. Do not under any circumstances buy a cheap welder as you'll get frustrated with it very quickly. Buy an inverter welder; my current one is a TIG/arc setup and cost around AU$450 but you can weld sh!t to a blanket with it. Okay, maybe not quite that, but it will deal with 1mm 303-grade stainless with no problem at all. It just laughs at mild steel. I'm self-taught and one thing I have found utterly invaluable is before starting a job, take two bits of scrap of the same type of metal as you're about to weld and stick them together as a test piece. That way you know your amperage and material reaction before you start on the real job.
cheers dai
yes I believe that the inverter welders take heaps of challenges out of the art  of arcing up  to start with .
for me finding a place to even practice  seems a challenge ..so far ...thanks for the tips
15Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 8:45 am
My RT is also 84 and same colour, but 08/84, no is 0022575. The engine is 32/84.
Fuel tank on these is bolt down and they also have a fuel pressure sensor you can get rid of, so if you are ordering the little vacuum caps you need 4 not 3. If its 84 and not a bolt down tank then some wring mods may have been done for the altered fuel pump wiring.
One reason I have put a lot of tlc in mine is that it doesn't have that K 4,000 rpm buzz or vibration.
16Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 08, 2017 4:34 pm
charlie99 wrote:hmm I can see a trip to Guyra coming up
giggles
good win I recon
Luckily the only rust on it is surface orientated and will come off very easy .
 It is good to see it will get a good new home .
17Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Fri Nov 10, 2017 5:41 pm
Tyres to be provided with the chair .
courtesy of Rockman , this VW wheel for the rear setup of the K100. no spacer available as yet .
Well Lookee here... Img_8625
Well Lookee here... Img_8627
Well Lookee here... Img_8626
Although the original chassis came with a full axle fitted with a shock on the inside edge alongside the rider. and a drum braked hub .
It now has a torsion axle with unbraked hub, courtesy of Waz.
Well Lookee here... Img_8624
fitted with 145-10 ( 10 inch ) 4 ply tyre
Well Lookee here... Img_8623
Well Lookee here... Img_8711
Well Lookee here... Img_8710
Of course we expect Sean will fit new treads , these pics just show the sizings .
18Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Fri Nov 10, 2017 7:58 pm
New tyres? They look fine. What could possibly go wrong? Well Lookee here... 212902
Big thumb
Plenty of work to be done including a full strip down but it will all be very well worth it!
Thanks again, Ed and to all the contributors!
Sean.
19Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Fri Nov 10, 2017 11:34 pm
I think I have a mini drum brake to fit that, will have a look in the shed.
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
20Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Sat Nov 11, 2017 2:23 am
Waz wrote:I think I have a mini drum brake to fit that, will have a look in the shed.
All good Waz , it came with one originally , that I will pass on to Herr Schoorn.
Well Lookee here... 16911
21Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Sun Nov 12, 2017 4:49 am
Thanks Waz and thanks ED.
Might be interesting finding a new tyre for the chair wheel? Maybe something for old Minis I guess.
22Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Sun Nov 12, 2017 4:52 am
92KK 84WW Olaf wrote:My RT is also 84 and same colour, but 08/84, no is 0022575. The engine is 32/84.
Olaf I don't actually pick it up until Friday so it will be interesting to see how it all fits together. I imagine this might be a reason why it sat for awhile. Exciting times ahead!
23Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Mon Nov 13, 2017 6:53 pm
Rockman
Hey Waz, if you do have one I'd be interested. I'm putting together a DL1000/DJP outfit and need to get the handbrake sorted.
24Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Mon Nov 13, 2017 8:30 pm
Ok Phil, I will have a look for it.
K100 RS
R1200GS
650 Vstrom
25Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Tue Nov 14, 2017 9:13 pm
Big thanks to Ed for having things brilliantly organised so I could load the chair etc onto the trailer with ease in his absence. Very Happy
Now it's off to Guyra with it tomorrow then pick up the BMW part of the outfit on Friday.
Well Lookee here... Img_7010
26Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 15, 2017 12:55 am
Well Lookee here... 112350
27Back to top Go down   Well Lookee here... Empty Re: Well Lookee here... Wed Nov 15, 2017 3:07 am
oops , forgot to leave some coldies in the barrow for you . Looks like it all loaded up well.
