1Back to top Go down   New K100RS owner from Norway Empty New K100RS owner from Norway Sat Oct 14, 2017 4:01 pm
ExcelKebab
ExcelKebab
After reading tons of forum posts and watching hours of youtube videos, I finally bought a 1985 K100RS with 55.000km on it, and now I’m not sure what to do with it. My intention at first was to build a café racer, but the more I learn about the bike, the more I like the original design. I’m at a point where it almost feels disrespectful towards the engineers at BMW to consider messing with the brickalicious stock version. And what would Chris R Harris think??
Anyway, while pondering these big questions, I plan to fix a couple of possible problems; a «knocking» sound coming from somewhere around the gearbox/rear of the engine, and a suspiscious «hissing» noise from somewhere around the fuel tank. Gonna trawl the forum for info, but any hints or tips would be much appreciated!
2Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Sat Oct 14, 2017 4:18 pm
Welcome along ExcelKebab,
Great choice of bike, good decision not to cafe chop her (at least not until you've given her a chance to show what she can do) and some great K owners in that there country of yours.
Hissing in vicinity of fuel tank - quite likely to be the noise of the fuel pump running (and completely normal) - and that's a real good start to a well running bike. As for the knocking, I've no experience in that department, but some recent posts on the subject which might help, if not I'm sure that someone will provide some guidance.
Enjoy
New K100RS owner from Norway Uk-log10 New K100RS owner from Norway Sco-lo15
                              Paul  New K100RS owner from Norway 905546712
3Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Sat Oct 14, 2017 4:25 pm
ExcelKebab
ExcelKebab
Thanks Paul!
4Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Sat Oct 14, 2017 5:12 pm
club_c
club_c
Welcome. Re knocking sound. Is it pronounced when the motor is cold but disappears when it's warm?  If so it could be the rivets in the output shaft. Not fatal, just somewhat annoying.
1988 K100RS SE VIN 01477554
5Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Sat Oct 14, 2017 10:13 pm
Check the inlet tract from the filter to the cylinder head for leaks. This can be done using an unlit propane torch and the gas will be drawn into the engine and a difference in running is noticed. All the clamps above and below the Injector body as well as the rubber stub manifolds at the cyl head are good places to start. If the engine is idling rough then that will cause rattles so check for air leaks first.
6Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Mon Jun 22, 2020 2:43 pm
ExcelKebab
ExcelKebab
Thanks for alle the tips! I think I found the source of the knocking. For some reason, 5-6 teeth on the anti backlash gear were bent outwards, scraping against the aluminium casing of the engine block. Didn't manage to find a replacement anti backlash gear that cost less than an arm and a leg, so the solution was to sand down the outer/rear edges of the teeth so they rotate clear of the engine block. Hoping this will not significantly affect the weight balance of the gear and cause vibrations.
New K100RS owner from Norway Img-1410
New K100RS owner from Norway Img-1411
New K100RS owner from Norway Img-1412
7Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Mon Jun 22, 2020 2:51 pm
Welcome Excelkebab Smile
Got a bugger on your hand there Wink
New K100RS owner from Norway Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
8Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Mon Jun 22, 2020 2:58 pm
moriarti
moriarti
Maybe a machine shop with a press might be the answer,What could have caused this to happen in the first place scratch
9Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Tue Jun 23, 2020 7:35 am
ExcelKebab
ExcelKebab
The front bearing circlip seemed to be out of place when I disassembled the engine, so possibly the whole output shaft could have slid backwards causing the gear to catch the inner wall of the engine block. Or someone forgot a wrench in there at some point..
New K100RS owner from Norway 595960310
10Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Thu Jun 25, 2020 6:36 am
Excellent work to track that down. It's a very unusual thing to happen.
If that is an 8 valve bike you should consider upgrading the output shaft while you are in there to the later one with more rivets, they don't wear as badly as the 6 rivet one.
Oh and Welcome to the forum, good to have you with us!
New K100RS owner from Norway Ir-log1188....May contain nuts!New K100RS owner from Norway Ir-log11
K75RTP - 1994
11Back to top Go down   New K100RS owner from Norway Empty Re: New K100RS owner from Norway Thu Jun 25, 2020 6:57 am
ERasberg
ERasberg
Welcome to the forum. If you have a picture of the beauty don't hesitate to share.
I have a similar knocking sound/ feel to what you describe. I never figured it out but also feels like it's coming from the drive shaft.
Let new know if you want to meet up for a ride in the Oslo area.
Einar.
Present
1988 K100 RS SE - VIN# 0146971K100RS - 105,000 km
1998 R1200C
1971 R75/5
Previous
1999 Virago XV125
1981 R65
