Received the sequencer pulsar on Wednesday, came home from dump day and decided to have a play. Two of the borrowed K75 injectors just dribbled on the tester, one totally blocked. So back in the thinners filled ultrasonic bath with the sequencer attached, two came good after one bath. The last one came good with three baths sequencer attached, patterns on all three look good. Until I know what the pattern is on the Ford ones are I will leave them alone.
So the total cost of setting this up MAP bottle and hose and some of the fittings I already had $20.00 for the ones I didn't have. Three bottles of injector cleaner I've had in stock for a year bought for $2.00 Au a bottle, one can carby cleaner $7.50 Au, 600ml of thinners $10.00 Au, sequencer was $37.00 Au. "O" rings, filters, pintle caps $15.00 Au. I would not use injector cleaner carby cleaner again, on totally frozen injectors. The thinners was the only thing that cleared them quickly. With more time maybe the cleaners might have worked.
I'm still chasing a source of yellow pintle caps, mates son is back and he's going to question him about a source for injector parts. The total cost for the rig and cleaning six injectors has been $75.50 Au. And I'm not including the three Falcon ones which are partially done. Even with the parts I already had I wouldn't have exceeded $100.00 Au. The fuel filter is one I removed from my Brick on the last service and kept for use in the rig.
Even though the Brick is running better than it has ever run, and no matter what I try I can't induce a backfire. On Monday for the sake of thorough testing I will remove my previously cleaned injectors, and put them on the rig with the sequencer. Due to the way it's running I'm expecting to see good patterns. The mate who has lent me his spare injectors is highly sceptical of my Brick no longer backfiring after cleaning the injectors. He had his injectors cleaned and tested by his son when his son worked for another company. And after cleaning, his brick still backfired on overrun. Maybe I have just been lucky, anyway I will post the results when I do the next test.
