1Back to top Go down   rubber heat shield mounting bolt Empty rubber heat shield mounting bolt Fri Jul 02, 2010 1:02 am
dschuetze
Does any one know if the dealers would still stock a rubber heat shield mounting bolt from a K100. My heat shield was rattling and I found out that the front rubber mount is torn. Do you think it needs the rubber or could it be solid mounted?
Thanks, Doug
2Back to top Go down   rubber heat shield mounting bolt Empty Re: rubber heat shield mounting bolt Fri Jul 02, 2010 2:06 am
That piece would still be available, but check the other bike sites to see if it's any cheaper (Max BMW, Motobins etc).
I would think that it needs to be rubber mounted to absorb some of the vibration. If it's solidly mounted, it may fracture.
3Back to top Go down   rubber heat shield mounting bolt Empty Re: rubber heat shield mounting bolt Fri Jul 02, 2010 3:09 pm
dschuetze
Thanks for the names. I'll check them and try to order one
Doug
