1Back to top Go down   Camchain Empty Camchain Fri Aug 27, 2010 7:01 am
Kerswellcrank
Kerswellcrank
Hi folks,
I keep thinking my camchain seems a bit noisy, but looking in the Haynes manual, I can't see how to adjust the chain tension.
Is the chain tensioner self-adjusting, and if so, how effective is it? could it be seized? Or is it just that my chain is due for replacement? Is it a big job to replace the chain?
Should I even be worried....Is a bit of chain rattle normal/acceptable?
Any advice would be gratefully appreciated.
Cheers,
Steve
2Back to top Go down   Camchain Empty Re: Camchain Fri Aug 27, 2010 9:35 am
It is self-adjusting by spring tension. It cannot be adjusted, per se. Some chain rattle is normal as it is a simple single row, not a hi-vo chain, and the thin, plastic guides do wear along with the chain allowing it to slop about just a bit. But they have been known to go for many miles/kilometres without needing replacement. Is it a big job? There are some who cannot change their oil so it would be for them. there is heaps of information out there (and in here) about doing the job. I would say it's a coupla decent coldies of an afternoon in your own shed, or coupla hundred pounds at your local BMW workshop.
3Back to top Go down   Camchain Empty Re: Camchain Sun Aug 29, 2010 1:41 pm
Kerswellcrank
Kerswellcrank
Thanks TWB, after a bit more Googling, it seems like the chain rarely gives any trouble, so I think I'll leave well alone for now.
Steve.
4Back to top Go down   Camchain Empty Re: Camchain Fri Sep 17, 2010 8:29 pm
177in70s
126,000 mi on my 85 K100RS and it had noisy camchain, esp in first 5 minutes and under 3000 RPM. Did many things then measured and found that 7 of 8 valves were tight, exhausts were .003 to .007 " when spec is .010 to .012". Yes, I'm not proud of this but getting them adjusted has made a huge improvement in many areas, a big one is that bad engine sounds in first 5 minutes of ride, below 3000 RPM are gone.
