1 Fuel Pressure Regulator Test Sun Sep 12, 2010 8:52 am
8675k
Since I put this under the wrong headng the first time I am looking for a way to test the FPR and is there a source to purchase at a reasonable price?
1986 k75, 1985 K100rt, |
8675k wrote:I performed this test at the onset of my problem which was overfueling of the the engine. My test indicated a delivery psi of 36. After testing and od replacing the electrical components in the system I am leaning toward the FPR. I realized a change in engine performance when I shook the regulator.
I alson cannot hold a vacuum on the reg when pulling a vacuum with a pump as ir there is a hole in the diaphragm? I can also restrict the feed side fuel line and the engine runs fine.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Fuel Pressure Regulator Test
Similar topics
