1Back to top Go down   fuel sender Empty fuel sender Mon Aug 21, 2017 5:22 pm
Flash of the gap
Flash of the gap
hi guys, my red fuel light comes on full when i fill the tank, as it goes down it goes off , back to front so to speak,
i took off fuel cap and lifted the float, light comes on , when i push the float down, to bottom it goes off  Sad any ideas, thanks in advance
Last edited by Flash of the gap on Tue Aug 22, 2017 3:58 am; edited 1 time in total
2Back to top Go down   fuel sender Empty Re: fuel sender Mon Aug 21, 2017 5:26 pm
It's an incorrect setting of the Sally Gap.
Not sure is it possible something is electrically reversed? I take it that you only have the single fuel warning light?
3Back to top Go down   fuel sender Empty Re: fuel sender Mon Aug 21, 2017 5:40 pm
Flash of the gap
Flash of the gap
92KK 84WW Olaf wrote:It's an incorrect setting of the Sally Gap.
yes olaf, the 7l doesnt seem to light amber
4Back to top Go down   fuel sender Empty Re: fuel sender Mon Aug 21, 2017 7:06 pm
It would be nice to have the model year and type of K-bike you own in your signature line.  This helps immeasurably when seeking help.
You have an 84 K100RS I take it based on posts you've made previously.  So, that means you have the older thermistor based fuel sender.  This unit has a pair of resistors inside the tank that change value depending on temperature and a circuit card inside the instrument cluster that interprets their values.  Either the sender or the circuit card is broken. My guess is the sender unit based on neither light working properly, but that's only a guess.  You could disconnect the sender from the harness and test the  thermistors for proper operation to narrow down the failing components. You should also figure out if the 7L indicator bulb is missing, blown or broken while you're at it.
5Back to top Go down   fuel sender Empty Re: fuel sender Tue Aug 22, 2017 2:53 am
Very important to show model, year and VIN number.
My own K is 84 K100RT and as said you will have the earlier 4/7l warning lights. Later Ks have a single 5l warning light and the units differ. Your fuel rank should be bolted down?
As far as I know the 'sender' units in the earlier tank don't actually move, they work on the basis of the fuel cooling the unit rather than using a float that moves, no fuel means it gets warmer and creates the electrical connection.
6Back to top Go down   fuel sender Empty Re: fuel sender Tue Aug 22, 2017 3:39 am
Flash of the gap
Flash of the gap
robmack wrote:It would be nice to have the model year and type of K-bike you own in your signature line.  This helps immeasurably when seeking help.
thanks robmack, i,ll work on in during the week, and see how it goes, need to run out the fuel in the tank,
7Back to top Go down   fuel sender Empty Re: fuel sender Tue Aug 22, 2017 3:43 am
Flash of the gap
Flash of the gap
92KK 84WW Olaf wrote:Very important to show model, year and VIN number.
this has a float in the tank olaf, if i could find how to post a picture i would
8Back to top Go down   fuel sender Empty Re: fuel sender Tue Aug 22, 2017 4:01 am
Flash of the gap
Flash of the gap
your most likely right olaf, i did have the fuel sender out, when cleaning out the tank, i probably put the wires,  back wrong, reversed like
bmw k100rs, 0010723 / 31000 mls
