1Back to top Go down   Bouncing speedo needle at idle Empty Bouncing speedo needle at idle Tue Feb 20, 2024 5:05 am
KiwiK100
KiwiK100
Hey everyone, I’m in the final stages of my ‘83 K100 restoration and finally fuelled her up and got her running. Problem. I noticed the speedo needle was occasionally flickering or bouncing, sometimes as high as 40 or 50 kph while at idle and in neutral. I popped her into gear and there was no speed registering on the gauge. Nadda. I removed the sensor and did the soldering iron test, and it was perfect, showing around 60kph as expected. The pick up is spotless and the FD oil is fresh. Any ideas where to go next?
Thanks in advance
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
2Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Tue Feb 20, 2024 8:45 am
i also have a bike that does that ....
not sure of the fix just yet but it could be the power supply line to the meter movement being slightly dry joint
im thinking on the backing ribon circuit between the input pins on the lunchbox connector and the actual speedo amplifier , then onto the motor .
on gerty i had duplicated the wiring with solid cables soldered to the connectors going to the pins to the electronic boards .
 which solved several issues including the meters dropping out occasionally ...requiring the bump the instruments fix ...till the next big pothole .
remember ... support the loom cable before it gets to the instruments connector .so that it doesnt pull on the pins in the lunchbox .as it hangs , wearing out the plating coating of the pins
hope that helps
Bouncing speedo needle at idle 2014-014
3Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Tue Feb 20, 2024 8:53 am
I had an instrument panel where both the tacho and the speedo did that. Turned out to be the coil springs that return the needle to zero were displaced - a quick ping with a small screwdriver fixed that.
4Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Tue Feb 20, 2024 4:57 pm
KiwiK100
KiwiK100
Thanks for the replies lads. I do have a spare instrument cluster, so wondering if I should rape it for parts. Maybe I’ll just swap it over to see if that fixes the problem. Only issue is that I want to maintain the odo reading on the original cluster as the mileage is verified
Current rides:
The family history:
5Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Tue Feb 20, 2024 5:04 pm
KiwiK100 wrote: Only issue is that I want to maintain the odo reading on the original cluster as the mileage is verified
Easy done. The very early versions of the instrument cluster actually dismantle completely, so it's easy to set the numbers where you want them. The later ones don't, but a thin jeweller's screwdriver inserted between the drums disenages the ratchet and enables you to rotate the drum. By 'the later ones' I'm still referring to the '83-'85 K100s that have the dual fuel level indicators on them, but it also applies to the '85-onwards single fuel indicator versions.
6Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Tue Feb 20, 2024 5:36 pm
KiwiK100
KiwiK100
Thanks Dai, not sure about the integrity of the rest of the cluster however I’ll hook it up if only to see if the speedo works, and what other bits do or don’t. Know the GPI screen is toast. Both clusters have the dual fuel level indicators, so that’s a good start
Current rides:
The family history:
7Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Fri Feb 23, 2024 12:39 am
KiwiK100
KiwiK100
I’ve swapped the instrument cluster for my spare unit and the speedo works fine, so where do I start… I took the back off, and the the screen, and when I went to carefully prise the needle off, it literally fell off. Squeezed it back on, put it all back together and presto, all working now. That’s a lucky break!
Thanks to Dai and Charlie for your input.
Current rides:
The family history:
8Back to top Go down   Bouncing speedo needle at idle Empty Re: Bouncing speedo needle at idle Fri Feb 23, 2024 6:19 am
Ah! Good catch! (Literally, I guess! Very Happy )
