1 Engine output shaft seal Thu Dec 13, 2012 4:32 pm
1986 k75, 1985 K100rt, |
Inge K. wrote:If the one with single lip is identical to the one in the drawing, it would probably
be the newest...with teflon lip ,as these don`t have a spring to tension the lip.
Crazy Frog wrote:As I will replace my clutch, I want to check the balancing.
I found a good article on the K11og forum.
Tenox wrote:I'm doing the same thing hopefully before christmas. Destroyed already one main seal (went in too deep) and wondering how is it installed correctly.. I did manufacture a tool which should leave the seal 1mm "up" but how do I get the seal in so that it goes evenly at all sides?
Clutch plate is replaced with oil resistant dry clutch but I made mistake when I took it apart and didnt mark the housing.. So it might not be in balance and I didnt quite get that tennisball idea.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Engine output shaft seal
Similar topics
