1Back to top Go down   Rear seat hinge pin "upgrade" Empty Rear seat hinge pin "upgrade" Mon Jul 24, 2017 9:54 am
This is handy for making seat removal/installation faster and easier.
1/4" clevis pin with a hairpin style cotter pin and a small zip-tie to make it easy to remove.
In the US it's hard to find a 6mm clevis pin so I use 1/4" and have to enlarge the holes in the seat bar and hinge with a 1/4" drill but if you live in metric land you could probably use a 6mm clevis pin and not have to drill anything.
Rear seat hinge pin "upgrade" Seat_h11
Rear seat hinge pin "upgrade" Seat_h10
2Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 11:19 am
BRILLIANT!!!  I've lost track of all the C clips I have lost down that hole under the hinge pin.
3Back to top Go down   Rear seat hinge pin "upgrade" Empty Thank you! Mon Jul 24, 2017 5:57 pm
tagaz
tagaz
Thank you for the tip.
4Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 6:21 pm
I've done the same, minus the cable tie. I have a piece of bent wire velcroed under the seat which I use for the tank clips and the seat clevis clips. Another Bricker has gone a step further and has long skinny cable ties on his tank clips.
Regards Martin
5Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 7:06 pm
Marvellous!
6Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 7:13 pm
If you could use white cable ties... even better.
7Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 7:18 pm
ainsjac wrote:If you could use white cable ties... even better.
Sacrilege! Shocked Only black zip-ties on my bikes.
8Back to top Go down   Rear seat hinge pin "upgrade" Empty Re: Rear seat hinge pin "upgrade" Mon Jul 24, 2017 9:08 pm
Jeez ainsjac, you're a stirrer!
