1Back to top Go down   K75S rides like it's on a rail Empty K75S rides like it's on a rail Thu Jul 13, 2017 7:19 pm
anglojaxon
anglojaxon
I'm Ian and I own a 1992 K75S along with a '17 R1200GS.
2Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Thu Jul 13, 2017 7:37 pm
Welkom Ian.
An excellent choice in the 75S.  Perhaps a photo sometime?
Dave.
3Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Thu Jul 13, 2017 10:22 pm
Welcome Ian!  The K75S certainly is a sweet ride.
4Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Thu Jul 13, 2017 11:26 pm
I hope you have a red K75S. (They're the fastest.)
WelKome!
5Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Fri Jul 14, 2017 1:32 am
Welcome from the land of OZ. You've got the pick of the litter.
6Back to top Go down   K75S rides like it's on a rail Empty Blue is faster than red Fri Jul 14, 2017 2:27 pm
anglojaxon
anglojaxon
In the light spectrum due to it's shorter wave-length.
K75S rides like it's on a rail Img_1510
7Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Fri Jul 14, 2017 2:38 pm
Noice! That blue colour was always one of my favourites. How do you like those (EBC or Spiegler-modified?) floating discs so far?
I've a hankering to fit 38mm K1200RS throttle bodies, collector & slip-on exhaust, Paralever swingarm/gearbox and later wheels/brakes onto a bare bones K75. I love the sweet purr of the three zylinder engine and feel it would really enter into a new realm with later suspension and brakes. Of course, I'll find one that's struggling to survive so as not to undress a perfectly running model...
8Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Fri Jul 14, 2017 3:08 pm
anglojaxon
anglojaxon
Two Wheels Better wrote:Noice! That blue colour was always one of my favourites. How do you like those (EBC or Spiegler-modified?) floating discs so far?
I can't compare it to anything. Came with the bike, Got it last year or so. I'm working on getting the Spiegler steel lines on the front, got them on the back. The delay was I got the wrong front brake lines. Spiegler made it right and noted some of the lines are different. Looks like I need to pull the ignition module to get a wrench around that nut in there. Next; fork oil change.
New fuel lines, fuel and air filter
Oil changes, rear diff, xmission, filter.
Plugs
Gaskets and rubber bits.
Spline lube
HyperLites
New aeroscreen (Directs wind right in my face).
New Lastertecs.
New grips.
Rebuilt rear master cylinder.
Rebuilt starter
It's got the bar backs on it already and a Worx rear shock.
9Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Fri Jul 14, 2017 6:15 pm
I recently installed some new front EBC floaters on my K100 and they don't seem to grab as well as the factory rotors.  To be fair though I did not replace the pads which I probably should've.
10Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Mon Jul 17, 2017 3:55 pm
WoodyAUK75
WoodyAUK75
That looks like a darker blue than mine. Nice bike!
11Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Mon Jul 17, 2017 4:02 pm
FYI: There should be a sticker under the seat with a 3 digit BMW paint code if you want to find out the name of the color.
12Back to top Go down   K75S rides like it's on a rail Empty Re: K75S rides like it's on a rail Mon Jul 17, 2017 5:22 pm
anglojaxon
anglojaxon
