Go to page : 1, 2  Next
SniperX
SniperX
My 85 K100RT has been running fantastic since the timing chain I did and everything else last summer. How do I force radiator fan to either stay on, or where to splice a switch in to make it come on when I wish it to? Right now it isn't coming on at all. Possibly a fuse?
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
indeed add a switch
for me its a test device ,,,if I'm heading out into the hills ...and the fan doesn't work ..I aint going nowhere
not the fact that I probably wont need it , whilst travelling , its the unpredictability about holdups behind traffic on return etc
its pretty easy to do
the "efi trouble shooting" link in the portal page   documents the terminals and usage for the temperature relay (which turns on the fan when required )
don't forget the sensor on the water stub is the signalling device to that relay
you can test the connections to the temperature sensor, by measuring the pins 10 and 13 at the under seat computer (efi computer )..also documented in the same thread
Force fan to stay on or add a switch? Test-FI%201
but make sure the fan rotates easily to start with , before exploring other options
you can take a switch wire and ground it through a switch ...then the other end of the switch should connect to the pin "e" of the temp relay
which will make it think that it is in an over temperature situation ..and thus turn the fan on ...at will
Force fan to stay on or add a switch? Fan%20circuit
of course this only works whilst the engine is running
good luck
SniperX
SniperX
charlie99 wrote:indeed add a switch
good luck
Brilliant! Cheers! And many thanks for the response! As soon as I get back from Phoenix, I'll do the mod with a switch. Oh, is there a specific after market fan that works better than stock and at least semi directly replaces the standard bit?
Yes!
SniperX
SniperX
Laitch wrote:
Yes!
Thanks! Now can you point me in the right direction for it?
Already have. Smile
SniperX
SniperX
Laitch wrote:Already have. Smile
AH HA! Thanks again!
if your going in to the fan assembly ..best advice I can give is to clean the blades as a first option
crud builds up on the leading edge and actually all over the blades ..thus decreasing airflow greatly ...call it cavitation if you will , but if you clean it up you will see a huge difference in flow
its a bugga to do ..but no where near hard
don't forget to lubricate the brass bushings whilst your in there ....wd40 is not a suitable lubricant ...however it will loosen up seized crap ready for a good lubricant
just a heads up
good luck
AFAIK there are 2 thermisters in the sensor which signals both the FICU and the Temp Relay. To properly test the temp sensor with respect to how it's connected to the temp relay you need to measure resistance between Temp Relay pins #E(sensor) and #31(earth). Testing at the FICU plug will only measure the thermister and wiring for the FICU. It will however give you an indication of the condition of the common earthing which is thru the sensor body to the engine block. Cheers
Force fan to stay on or add a switch? Relay-tray
 Force fan to stay on or add a switch? Austra12    Fuel:  95 Octane
KiwiK100
KiwiK100
Absolutely right Charlie, and not to forget giving the radiator a good bath in hot water to loosen all there crud that builds up between the fins. Once soaked a good firm tap on the garage floor will knock out a surprising amount of debris. Be careful using compressed air as the fins are VERY soft and will fold and collapse if too much air pressure is used too close to the fins.
Water temp will run noticeably cooler when the radiator and fan blades are clean.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
KiwiK100 wrote:Be careful using compressed air as the fins are VERY soft and will fold and collapse if too much air pressure is used too close to the fins.
Don't use a powerhose either. DAMHIK.
SniperX
SniperX
KiwiK100 wrote:Absolutely right Charlie, and not to forget giving the radiator a good bath in hot water to loosen all there crud that builds up between the fins. Once soaked a good firm tap on the garage floor will knock out a surprising amount of debris. Be careful using compressed air as the fins are VERY soft and will fold and collapse if too much air pressure is used too close to the fins.
Good thing I did that when I had it all apart last whilst doing the timing chain, and everything else! Thanks for the advise though!
13Back to top Go down   Force fan to stay on or add a switch? Empty Giving it a go tomorrow... Sun Apr 09, 2017 1:23 pm
SniperX
SniperX
I'm getting a chance to give it a go tomorrow or Wednesday. I have been busy on a different project for a bit. A mate gave me a 1977 Plymouth Trailduster with 52K miles original on it so I have been busy doing my Re-start after two years of sitting on it. Hopefully the re-start will be successful today and I'll go from there.
14Back to top Go down   Force fan to stay on or add a switch? Empty add a switch. Sun Apr 09, 2017 1:40 pm
Peterk100rs
Peterk100rs
So I added a switch to my k100rs last week . Fan wasn't coming on and when I tested the cabling it was faulty . Basically I followed the cable from the fan to up under the tank, its close to the front on left side. Its here where it connects to the wiring loom. I cut the connector off and ran a cable up to a switch which I installed on the switch rail where the key is and just ran it to the battery .
The fan worked instantly. So i basically only turn it on when I come into town where there is generally a lot of sitting about in traffic.
SniperX
SniperX
Peterk100rs wrote:So I added a switch to my k100rs last week . Fan wasn't coming on and when I tested the cabling it was faulty . Basically I followed the cable from the fan to up under the tank, its close to the front on left side. Its here where it connects to the wiring loom. I cut the connector off and ran a cable up to a switch which I installed on the switch rail where the key is and just ran it to the battery .
Good to know, I'll do that is I can't find the fault in mine which I should be able to do.
While removing the Temp Controller from the equation won't affect the performance of the engine, it does mean that you've removed an element of safety and reliability. I think your bike has a temperature gauge?? If not, probably a good idea to install one so you can keep an eye on it. Better to get the fan/temp controller to work as it should imo.
Hopefully you've run the power to the switch and not to the fan itself, but more importantly, it's not a good idea to pick up the power directly from the battery as you've done, for two reasons.
  • Your fan is running off un-switched 12V. This means that when you turn the ignition off, you will still have power to the fan switch. If you forget to turn the fan off after you've parked, you're battery will not only run down but it will possibly be ruined.
  • Your fan is now unfused. This means that if the fan melts down which they can do, or you have a wiring short, you run the risk of an electrical fire which has the potential to damage other wiring or even you whole machine. I'm pretty sure the temp controller is fused on #6 (7.5amp). The fan itself is fused via the temp controller (jumps off the horn relay) thru fuse #7 (15amp). This is where I'd be picking up the power for the fan switch.
I don't think you want to run the fan all the time.  These engines are designed to run at a specific temperature controlled by the thermostat.  In conditions were the engine is running in a cold environment the fan will prevent proper warm up or at best delay the rise to operating temperature, leading to accelerated wear.
Best to run the fan off the thermo switch with the manual switch only for those times you are stuck in traffic in hot weather.
Peterk100rs
Peterk100rs
Fan is wired through a fuse which i installed in the fuse box in a spare slot and linked through power to the light Relay so It cant be turned on unless bike is started. The switch has a led so I can visibly see it on and yes the bike is fitted with a temp gauge.
Basically I didn't want to pull apart the wiring loom incase I created any more issues as I have been down this road before.
So far this has worked fine with no issues. Changing the temp sensor made no difference as the issue was in the wiring loom.
However I had originally intended just to fit a new temp sensor which I did but no use no fan and water was boiling over .
There is no need to pull new wires(except for the LED and the switch) or install a new fuse. The switch should be connected to the ground and carry no power. Positive for the light/LED can be the one for the parking light.
Have you tried a simple testing of the temp relay?
When grounding (earthing) pin E, you should get +12V at pin A2. If this doesn't work, I would say that the temp relay is bad.
This is the proper installation without butchering the original wiring.
Force fan to stay on or add a switch? Temper10
Force fan to stay on or add a switch? Frog15Force fan to stay on or add a switch? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
Peterk100rs
Peterk100rs
Crazy Frog wrote:There is no need to pull new wires(except for the LED and the switch) or install a new fuse. The switch should be connected to the ground and carry no power. Positive for the light/LED can be the one for the parking light.
Good info there , I will try that .Thanks
BobT
BobT
I ride in all weather and am not worried at all about the fan. I could install a switch for the summer but then the engine might not get as hot as BMW designed it to. I know that if I fitted a switch then I would also look to improve that system by making the fan come on automatically, then I realised that it does that anyway.
Has anyone blown a cooling system on a K100 because the fan did not work and the engine got too hot?
BobT wrote:I ride in all weather and am not worried at all about the fan. I could install a switch for the summer but then the engine might not get as hot as BMW designed it to. I know that if I fitted a switch then I would also look to improve that system by making the fan come on automatically, then I realised that it does that anyway.
Came close to it on the LT.!
Easily done this part of the world where its not so hot that you leave the K at home.
Which is why my RT got a nice work over in February with a full clean out and a new fan which comes on regularly. Cooling system all ok, pump replaced three years ago and no airlocks. Just the traffic where I travel the last part of my trip to work.
BobT
BobT
Olaf, are you saying that you never did any damage due to overheating? Come close is not a scientific measurement it either over heated and blew the cooling system or it didn't.
Engines run at their most efficient when hot, and a high oil temperature is most important, but no one on a bike knows what the oil temperature is as they only fit water temperature gauges to bikes.
Boiled it over.......in heavy traffic in winter. And in Perigueux in the urban part fan was running full time on the RT while moving in your nice 35C weather. Wonder how that would have been with no fan running....
Hot is indeed efficient but once the fan is on it means the engine has reached its maximum capacity to get rid of the excess heat, unless you can improve it by moving/moving faster. No fan and you reach that limit in a very short time. Park bike and go for a cool beer at that point.
25Back to top Go down   Force fan to stay on or add a switch? Empty It's FAN TIME! Mon Apr 17, 2017 4:25 pm
SniperX
SniperX
Removed enough of the fairing to find out the fan is partially seized so I will have to replace it. It is hard enough to turn by finger, that I feel as if it need about 10lbs of pressure on the blade to make it move.  I feel it's gacked and ready for the bin.
26Back to top Go down   Force fan to stay on or add a switch? Empty Laitch, have a question... Mon Apr 17, 2017 4:29 pm
SniperX
SniperX
Have you personally done this swap? If so, (or not!) do you have to just install the fan with the custom bracket (which I can easily make) and plug it in like the stock one?
Has anyone tried the SPAL unit? Looks like a good fan from online reviews on other vehicles and oil coolers which is what I found most.
I have installed the Spal fan in my K100RS.  It's an easy job once you have the radiator out.
No need to make a new mount.  The old one can be used after the crap Bosch fan is removed.
You simply remove the tabs on the Spal fan so it can slide into the original mount.  A cut in the original mount allows it to open up to fit that Spal fan into it, and you then pop rivet the Spal into the original mount.
The Spal fan is about 1mm larger in diameter than the Bosch, so it is not a bad fit once the mount is cut.  The only other work that needs to be done is to ovalize one of the mounting holes to line up with the radiator.
Whole job takes about an hour once the old fan is out of the bike.
Here's the description I followed:
http://www.motobrick.com/index.php/topic,4313.msg26399.html#msg26399
Go to reply #18 dated December 20, 2014.
Flip2
Flip2
Where is a good area to locate this override switch and led for the fan ?and what kind of switch( simple toggle) or maybe something I've seen on motobins perhaps? in the future I might install a temperature gauge as well .
 86 k100 rs
Flip2 wrote:Where is a good area to locate this override switch and led for the fan ?and what kind of switch( simple toggle) or maybe something I've seen on motobins perhaps? in the future I might install a temperature gauge as well .
 86 k100 rs
Usually the dash on the handlebars has one or two spare slots for an additional switch. A toggle switch is all you'll need. You could try buying a second hand switch to fit the dash from Motorworks/Motobins. You'll need to run a wire from the temp controller up thru the steering head and to the dash plus another earth wire back to the main earth point under the tank.
Temperature gauge runs off a different temp sensor which screws into the drain plug on the water pump.
Flip2
Flip2
Crazy Frog , at first I thought I understood your diagram but could you explain it for a beginner?
Flip2
Flip2
Tracing the wiring from 45(on the temp relay-15 in diagram)appears to go to 86 pin on the horn relay  and  not to 30 of load shed as the diagram states. . . Thanks for all the prev info group.
33Back to top Go down   Force fan to stay on or add a switch? Empty Which of the two fan wires is hot Fri May 26, 2017 1:07 am
SniperX
SniperX
I'm replacing my fan in the next couple days. With the SPAL fan. Need to know which wire is hot and which is earth on the stock fan colour wise so I can wire up the new fan polarity correct.
Violet/yellow is 12V
Brown is ground.
SniperX
SniperX
duck wrote:Violet/yellow is 12V
Brown is ground.
Thanks much Duck Cheers!
SniperX
SniperX
Got the fan on the rad finally. Been working so much on the ranch I just finally got the time to do it this weekend. It'll be back on the road tomorrow. Ended up doing the SPAL fan, and fitting it to the original housing after removing the stock fan. Old fan cut from housing,
Force fan to stay on or add a switch? 19657079_1435166906576465_6036884659267984444_n
Housing sans old fan
Force fan to stay on or add a switch? 19598437_1435166959909793_1800965506443444433_n
Close up of SPAL tabs that I removed with a sander and cutoff tool
Force fan to stay on or add a switch? 19601280_1435166989909790_7243562689227999162_n
SPALL rivited into stock housing
Force fan to stay on or add a switch? 19601304_1435167063243116_8784162038010033296_n
Completed fan in housing
Force fan to stay on or add a switch? 19657033_1435167133243109_5870547713025978263_n
Back in situ!
Force fan to stay on or add a switch? 19554830_1435167476576408_7946298631287887682_n
Nice job!
Flip2
Flip2
I tried that method and it would not fit on my 86k100rs , . I was pissed spent s bunch of time grinding etc and it was still catching at the sides near the top . I ended up using a couple pieces of aluminum stock ( as suggested elsewhere ) and that was a pita as well . the spal fan is nice but the Bosch motor replacement would have been a piece of cake .
SniperX
SniperX
Flip2 wrote:I tried that method and it would not fit on my 86k100rs , . I was pissed spent s bunch of time grinding etc and it was still catching at the sides near the top . I ended up using a couple pieces of aluminum stock ( as suggested  elsewhere ) and that was a pita as well . the spal fan is nice but the Bosch motor replacement would have been a piece of cake .
You probably didn't cut the stock mount for the SPAL to fit in. Yes it was a bit fiddly, but all in all I am happy with the results because the entire thing feels more sturdy than the stock fan. And with the SPAL in situ the fan is actually closer to the rad because the blades and SPAL housing is right at the edge of the stock mount. But there is still plenty of clearance between the rad and the housing.
Flip2
Flip2
Glad yours worked mate .No I did exactly what you did , cut the original mount , riveted it together and had it on the radiator before attempting to install it several times along with removing/grinding more of the original mount , bummer .
SniperX
SniperX
Flip2 wrote:Glad yours worked mate .No I did exactly what you did , cut the original mount , riveted it together and had it on the radiator before attempting to install it several times along with removing/grinding more of the original mount , bummer .
Was it because the top mount with the rubber grommet was off centre a tad? Mine was and I massaged that as well. I simply rounded out the hole for the needed spot for the grommet to gon back in, and the metal spacers to go back in and the 5mill socket went right back in,.
SniperX
SniperX
duck wrote:Nice job!
Thanks Mate! And for your help as well!
Cheers!
Kev
SniperX
SniperX
So, if I understand this correctly... The mod to add a switch to the fan to force it into the on position grounds the fan correct? So there is a hot provided constantly whilst the bike is running, and the relay gets a signal from the temperature sensor, then the relay connects the ground to the fan in order for it to come on...so if I just tap into the ground wire on the fan itself, and switch it to ground from a single pole single throw switch it will come on? Is it that simple?
The mod that forces the fan on with a switch never touches any of the circuitry that powers the fan. So, your explanation and conclusions above are incorrect. The modification runs a switched lead to ground that parallels the water temperature sensor in the stand pipe. With the switch open, everything works normally. With the switch closed, the temperature sensor is short-circuited to ground. This simulates the same conditions as a very overheated engine, and tells the temperature relay it should turn on the fan to cool the engine; so the fan starts up.
SniperX
SniperX
Great! Which wire on the sensor is the ground? Thanks.
You won't find a ground wire on the sensor. The body of the sensor is the common connection. The body is screwed into the stand pipe which is bolted to the engine which itself is bolted to the frame which is electrically connected to the battery negative terminal.
SniperX
SniperX
robmack wrote:You won't find a ground wire on the sensor. The body of the sensor is the common connection.  The body is screwed into the stand pipe which is bolted to the engine which itself is bolted to the frame which is electrically connected to the battery negative terminal.
How is it then that if the temp sensor is short circuited to ground that makes the fan come on, if the temp sensor as you also said that the body of the temp sensor is grounded?
The override switch mod is shown in this schematic:
Force fan to stay on or add a switch? Fan-ci10
Note the temperature sensor. It is actually two separate NTC resistors with a common connection that is connected to the threaded body of the unit. Although not shown in this schematic, the body of the sensor is electrically grounded.
When the switch is open, the sensor connected to the temp relay functions as normal. When the switch is closed, the sensor is shorted, and the temp relay measures 0 ohms relative to ground. This is a condition for a very hot engine and the fan turns on.
Is there something about your questions that I misunderstand?
SniperX
SniperX
Looking at that schematic makes me think i can tap into the wire at the temp sensor instead of under the seat. It appears the wire being grounded is one of the two wires directly off the temp sensor.
SniperX
SniperX
What color is the wire off the relay is the switch connected to?
