1Back to top Go down   K100 with k1200 forks????? Empty K100 with k1200 forks????? Mon Sep 11, 2017 12:47 am
53cr3t5quirr31
53cr3t5quirr31
Is this possible? If not why?
2Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 2:49 am
Yes, it is possible.  Read my blog on my K75 customization.  Also searching this site would have revealed many threads on this subject,
3Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 2:59 am
53cr3t5quirr31
53cr3t5quirr31
I see in the post you mention k1100 forks I'm asking about k1200 forks
4Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 3:26 am
Humans have managed to put a man on the moon and get them back to earth, usually without killing them so putting K1200 forks on a K100 is possible and with nowhere near as much engineering expertise as sending those guys to the moon.
But, and there is always a but with a job like that you will need to cut the frame up and make quite a lot of the components from scratch as the front ends are not at all the same. I would suggest you have a look at the K1200RS front end and see how it works before you go any further.
If you do decide to do it please keep us up to date and have lots of pics as I would be very interested in the process.
Best of luck
5Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 3:29 am
53cr3t5quirr31
53cr3t5quirr31
I was more on the line of sliding the k1200 forks into the k100 triple tree just like if you where doing a k1100 swap.. if all that's holding it back is a different fork tube diameter $100 and a day at the machine shop will fix that. I'm basically looking for a easy way to swap k1200 forks, breaks, rotors and front wheel all im one bang without any parts for a k1100
6Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 3:44 am
Have a good look at the drawing: BMW telelever.
7Back to top Go down   K100 with k1200 forks????? Empty Re: K100 with k1200 forks????? Mon Sep 11, 2017 12:05 pm
Oh boy, what fun.
