1Back to top Go down   Installing a water temperature gauge Empty Installing a water temperature gauge Tue Jul 06, 2010 12:17 pm
Got this from the German K-bike technical site ( http://k-technik.pytalhost.com/pdf/wassertemp.pdf ). I thought it is useful to reproduce the information here in the BMW K100 forum for future reference.
Installing a water temperature gauge Tg1
First line in the Blue region is #1; Last line in the Red region is #8. The following resistances will deflect the needle on the temperature gauge to the given indicator line.
Indicator Line
Resistance (Ohm)
Notes
2
150
3
100
4
70
Reg's White dot
5
50
Reg's Red dot
6
40
Cooling fan should engage
7
30
8
25
The aproximate resistance values measured at the water temperature thermocoupler on the water pump for certain engine conditions are as follows:
Engine temperature = 10 Celcius ~ 1.3 Kohm
Engine temperature = 20 Celcius ~ 250 Ohm
Normal Engine Operating temperature ~ 70 Ohm
I am uncertain whether the thermocoupler is linear or non-linear in its response (which may match a linear or non-linear response in the gauge) However, with this technical information it should be possible to calibrate a non-BMW temperature gauge to the BMW thermocoupler sensor. A suitable test bed for such a calibration will look like this (taken from the document above):
Installing a water temperature gauge Temp-t10
