1Back to top Go down   Rear Wheel Bearing Empty Rear Wheel Bearing Sun Jun 11, 2017 4:40 pm
JGT
JGT
The large crown wheel ball race. Is that a BMW only part or readily available from a bearing supplier? If so, anyone have the bearing manufacture part number/code for it? I'm guessing it would be cheaper to buy that way than a 'genuine' BMW bagged part. John
1992 K75
2Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Sun Jun 11, 2017 9:22 pm
k100virgin wrote:The large crown wheel ball race. Is that a BMW only part or readily available from a bearing supplier? If so, anyone have the bearing manufacture part number/code for it? I'm guessing it would be cheaper to buy that way than a 'genuine' BMW bagged part. John
I just did mine, recommendation from someone with nothing to gain and huge experience of doing them was to buy the BMW part, you also need the seal to go with it and it's a separate part. Its the same bearing on the R bikes and on the paralevers.
Never actually checked if there was one from a bearing supplier but the same person who recommended that one to be a BMW bearing quite happily uses bearing suppliers for the other bearings.
Motobins was a good source but check Motorworks too.
Don't let that bearing go long if it's on the way out.
3Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Mon Jun 12, 2017 2:11 am
"Don't let that bearing go long if it's on the way out."
That's good to know. Sometimes you think "It'll be all right for a while".
4Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Mon Jun 12, 2017 5:03 am
JGT
JGT
Thanks for info. Bike passed its MOT last week but the tester found the very slightest of movement in the rear wheel, felt more than seen. Are we saying a new race would eliminate that completely or is there still a running clearance and movement? Bike has done 85,000 miles.
1992 K75
5Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Mon Jun 12, 2017 10:38 am
Mine was on 80,000 miles so same lifespan. If you leave it then it ruins the final drive with the race moving around and can [will] eventually break up unexpectedly. I had no apparent play, what alerted me to it was the feel of a bearing on the way out and I had worked out it was related to road speed and not engine speed.
Final drive doesn't even have to come off to do it. Done from the wheel side. Getting the clearances right is important, needs to be tight enough to remove play but still rotate freely.
That bearing is the only thing on the back end that's keeping it all together.
6Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Mon Jun 12, 2017 1:15 pm
JGT
JGT
Looks like a trip to Motobins, there only 35 miles away.
1992 K75
7Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Tue Jun 13, 2017 12:54 am
That bearing (85X120X18) fits Airheads from 1981, all K bikes whether Monolever or Paralever, R850/1100/1150/1200C Oilheads, and the later K1200RS/GT & LT series. The current BMW p/n is 33121242211. An aftermarket bearing number is 61917/C3 by SKF. When it goes it goes. 'Bins has 'em for £39.00 inc VAT.
8Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Tue Jun 13, 2017 4:19 am
JGT
JGT
Two Wheels Better wrote:That bearing (85X120X18) fits Airheads from 1981, all K bikes whether Monolever or Paralever, R850/1100/1150/1200C Oilheads, and the later K1200RS/GT & LT series. The current BMW p/n is 33121242211. An aftermarket bearing number is 61917/C3 by SKF. When it goes it goes. 'Bins has 'em for £39.00 inc VAT.
Will check price from my local UK bearing supplier out of interest but have to say not a bad price from Motobins and of course they have the seal and 'O' ring.
1992 K75
9Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Wed Jun 14, 2017 5:23 am
JGT
JGT
Price from my local bearing supplier as a special order a staggering £106.04!!!!!!!!!!!!?????????
1992 K75
10Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Wed Jun 14, 2017 7:53 am
I think that's full MRP as I've seen that price (or very close to it) quoted by a lot of different suppliers. The big bearing in my Guzzi bevel drives is in the same ballpark.
11Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Sun Jun 18, 2017 5:15 am
KiwiK100
KiwiK100
K100virgin, what year K100 are you riding? If it has a paralever rear it could also be the pivot bearings causing the play. The FD bearing will not 'fail' overnight but gradually wear over thousands of miles/kilometers. A new bearing will totally illuminate any movement. You can check the FD bearing for wear by using a screwdriver as a stethoscope, placing the tip on the FD and the handle to your ear and spinning the rear wheel. If the FD bearing is worn you will pick up a rumbling sound. Alternatively, if you have a paralever place the screwdriver tip on the pivot bearing lock nut and get a second person to rock the rear wheel at 9.00/3.00 o'clock. If the pivots are worn or in need of re torquing, you will pick this up as a noticeable ticking sound through the screwdriver. Often when it is thought the pivots are worn, sometimes a re torque is all they need. BMW suggest 8Nm from memory, but 10 is better. When torquing mine I torque them a couple of times to 12Nm to expel excess grease before a final torque to 10Nm
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
12Back to top Go down   Rear Wheel Bearing Empty Re: Rear Wheel Bearing Sun Jun 18, 2017 9:00 am
JGT
JGT
Its a 87 K75s so standard back end. Picked up the parts from Motobins the other day so will wait until weather a bit cooler. 28C today, Its the humidity that's killing me. John
1992 K75
