Number of posts : 12058
Just where the arrow points there is a small hole(3mm) which leads up to the air space between the coolant pump and oil pump seals and your coolant pump is leaking and dripping from that hole.
Your lucky as often that hole gets blocked with crud and the coolant get past the oil seal and into the oil.
