1 petrol pump Sun Apr 30, 2017 11:55 am
triker
i have brought a 1988 k100rs as a non starter which i am converting to a trike (they don't fall over) .I have isolated the fault to the fuel system , I will give a quick breakdown of the symptoms -
Engine spins freely and will start with just the fuel pipe full of petrol (tickover). Using a plastic bottle and tube the bike will start tickover and as long as I press the starter button(excess fuel) will rev nicely.
On fitting the tank and plugging in the pump wiring as soon as the ignition is turned on the pump will spin and will not ever stop,(the pressure will spurt fuel from the return pipe a good foot in the air) the engine is immediately flooded and will not even fire.
Removing the plugs and drying them on replacing with the pump disconnected it will instantly start and reconnecting the pump while running as long as you keep it revving it will ride but not tick over . Once stalled you have to remove and dry plugs again.
I have blocked the return pipe and the pump will slow slightly but will still not stop spinning resulting in engine flooding.
1 Is the pump stopped mechanically or electrically.
2 could it be the pressure regulator.
3 previous owner changed the ignition switch could this cause the pump to over work.
4 is the pump repairable or sealed.
5 help.
Addition information fuel tank had leak now repaired so possibly pump was dry for at least 18 months before i brought the bike. absolutely sick of checking hall sensors, modules, fuses,earths so any ideas will be very appreciated.
5 help.
