Shep
Shep
Please point me to thread that explains or tells if it is possible to push out the fuse terminal box to the front so I can access the terminals more readily on the back of it.
I have looked through the BMW manual and a number of electrical threads with no success.
Shep
Have you lifted the tank?
Shep
Shep
Yes
I am into the electrical relay box and just want better access to the terminals at the back of the fuse box.
Shep
IIRC the wires are too short to allow the fusebox to come forward. It should go backwards but...
Shep
Shep
Thank you.
It does push back into the relay box but as you indicated not a long length of wires to work with. It doesn't seem easy to add another wire to the #4 fuse which only appears to feed the auxiliary 12 V outlet below the seat!
Shep
A pair of longnose needle pliers does the trick Very Happy
