1Back to top Go down   K100 powered Morris Minor 1000 Empty K100 powered Morris Minor 1000 Mon Apr 24, 2017 4:24 pm
pinhed
pinhed
My 5yr task is to build a k100 Morris Minor 1000 😁
I recently swapped my ZZR600 for a 1985 K100 and just bought a 1970 Morris Minor. My end goal is to low rider the Morris (lowered, roofchop, fender skirts etc etc) and have the K100 as its heart. I also want to keep the k100 gear box and all the electrics so gear wise will be 1down 4up and extend the wiring loom for lights gauges etc instead of cutting and splicing 2 different looms together.
I know it's going to be a long slow process to say the least lol
List of key jobs:
  • Structural work on the Morris (floor pans, sills the usual stuff)
  • Tidy up the k100 and give a damn good service
  • Gut the Morris of engine, gear box wiring and interior
  • Work out calculations for the final drive on the k100 and work out what differential will be needed for the conversion to the moggy rear end
  • Stick k100 engine and gearbox into the moggy
  • Get custom driveshaft and differential made and installed
  • Road test (on private road)
  • Roof chop and bodywork on the moggy
  • Add and modify electrics
  • Interior and paint 😁
K100 powered Morris Minor 1000 Img_1510
Current bike:- 1985 BMW K100
Goals for the bike is to put engine and gearbox into a 1970 Morris Minor 1000.
2Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 6:30 pm
Motorbike Mike
Motorbike Mike
That looks like a great project. Keep the photo's coming. K100 powered Morris Minor 1000 112350
What are you doing about reverse?
3Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 6:48 pm
pinhed
pinhed
Reverse wise, I'm thinking of doing the same as a goldwing and have a separate circuit to the starter motor that will spin in reverse just to get out of a parking space lol
4Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 6:56 pm
Motorbike Mike
Motorbike Mike
I wonder if the starter will stand up to that?
I have several spares when you need another Very Happy Very Happy Very Happy
5Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:16 pm
I wonder though will that work on a K given the sprag clutch. I have a feeling the starter will only work one way. I am not sure but best check that out with those who do. Its just that sometimes an incorrectly assembled starter will run backwards but I don't think it turns the engine over.
6Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:25 pm
Many, many moons ago when the K100 was the  sidecar bike.  There was a bloke in Germany converting the K gearbox so that one down was reverse, then 4 forward gears after that. Apparently using standard gears and a bit of machining.
 only ever heard of it, read of it.  I know nothing else about it so no point in asking me more cause there's nothing more to be had.
'93 K1100LT
K100 powered Morris Minor 1000 K-dogs10
7Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:32 pm
Avenger GT
Avenger GT
Forget about using the K engine complete. Get the 1300 version of the Morris engine, and put a K head conversion kit on it. Then use what ever car gearbox you can make fit.
8Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:33 pm
pinhed
pinhed
Ahhhhhh poop forgot about the sprag clutch ........ hmmmmm........... then possibly add another pully or something to the driveshaft that will be connected to a separate motor. ill have a look on the hillman imp forums see if I can find the guy that put a k100 engine into his see if he ran the sequential gear box like I wanna do or if he put a 'normal' box in. Unless I can find a way to change the sprag clutch.
Glad I joined the forum exactly for this reason lol otherwise I would have had a brain fart, stripped the bike and connected the circuit up before I realised hahahaha
9Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:34 pm
pinhed
pinhed
Motorbike Mike wrote:I wonder if the starter will stand up to that?
Hahahaha I have a feeling I'll need at least one spare lol
10Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:36 pm
pinhed
pinhed
Avenger GT wrote:Forget about using the K engine complete. Get the 1300 version of the Morris engine, and put a K head conversion kit on it. Then use what ever car gearbox you can make fit.
I really like the idea of the sequential gear box though. And stick with full K engine as I know it'll be a lot more reliable then the Morris blocks.  My first one was a complete nightmare to get started in winter or even wet days, no matter what garage I took it to it was always a nightmare.  Sold it to a local guy, he uses it as a weekend summer toy these days
11Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:38 pm
I had a problem with a car a few years ago, automatic and reverse became unavailable. For a while I had to choose very carefully when I went........German engineering....!
AvengerGT has the right idea. I knew that worked with the 1000cc engine but didn't know about he 1300 which I presume is stroked rather than bored out?
12Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 7:45 pm
Avenger GT
Avenger GT
I wouldn't like to bet on the longevity of a K gearbox hauling the weight of a car around. I would also think the 6 rivet shaft wouldn't last very long.
13Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 8:57 pm
I recently bought the bottom end of a 16V K engine from a guy who was using the head on a 1275 Mini and when I picked it up he showed me his various projects one of which was a 1275 with an 8V head and turbo which was producing 205HP at the wheels. One other project was grafting a CBR1000 6 speed to a mini engine, he didn't have it finished but it was a masterpiece of engineering.
You may be able to make a small transfer case to go on the back of the K gearbox to accommodate a reverse arrangement.
With regard to rear end maybe an independent rear end from a E30 BMW car, lots of ratios available for them and the complete transaxle sits in a frame with 4 mounting points.
I really don't think a K clutch would be up to the job.
14Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 9:07 pm
Quaife....
15Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon Apr 24, 2017 10:54 pm
Motorbike Mike wrote:That looks like a great project. Keep the photo's coming. K100 powered Morris Minor 1000 112350
The easiest solution would be to mount the driver's seat on an axle and rotate it 180º when necessary.
16Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 1:55 am
This will be a great project to watch. Please keep us regularly posted with pictures.
17Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 3:13 am
Motorbike Mike
Motorbike Mike
I may have the solution  affraid
How about the gearbox off a K1200LT? They have a reverse built in.
http://www.realoem.com/bmw/enUS/showparts?id=0555-USA-01-2003-89V3-BMW-K_1200_LT_99_0545,0555_&diagId=23_0853
I'm sure the 1200 stuff bolts straight on to the 1000.
18Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 7:26 am
pinhed
pinhed
Motorbike Mike wrote:I may have the solution  affraid
Absolutely awesome idea, I'll add it to my watch reminder on eBay. Thank you very much that's one less headache
19Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 7:35 am
Motorbike Mike
Motorbike Mike
I've looked...they're not cheap.
Good luck. Very Happy
20Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 7:50 am
pinhed
pinhed
Yeah ouch on the price but will reduce the cost and headache of a drive shaft with a mid pully, brackets, belt and another startermotor.
The electrics is going to be the fun part although I have seen someone that was selling a gear selector board that replaces the oem clocks so I can start it in neutral without the clutch etc lol
Was shocked when I picked up the bike and he told me speedo didn't work so I thought with age of the bike it'd be mechanical cable until I looked behind the clocks and noticed it was full electric ohhhhhhh the joys hahahaha
21Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 7:58 am
Motorbike Mike
Motorbike Mike
I've got a set a spare clock set if you're stuck.
I would think if you shop around someone has a gearbox at reasonable money. IF...they're not a weak point on the bike and don't break there will be plenty about. I'm thinking that a K12LT gearbox would be strong enough too as the LT weighs more than a Moggie Thou!
22Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 8:18 am
I've got a 1200 bellhousing spare(as I have a 1200 engine to go into one of my K100s).  It will bolt to a K100 block. Post would be prohibitive I'd guess.
'93 K1100LT
23Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 9:22 am
pinhed
pinhed
Think I've possibly fixed the clocks on mine, quick Google told me the connection pins in the clocks oxidise and lose connection so cleaned them up but haven't tested yet.
Did/does the bellhousing marry up correctly to the 1000? Does your original gear selector (LCD display) still work correctly aswel?
The help and advice from this forum so far has been absolutely brilliant, I'll keep a build update etc of all progress on this post ( providing I'm not breaking any forum rules as a lot of work required on the moggy and at this rate the bike stuff will be done a lot sooner then I anticipated )
24Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 10:14 am
Motorbike Mike
Motorbike Mike
The intermediate "bell housing" may not be required-I was just writing out loud! Smile
Buy a gearbox and try it before you start looking for other parts.
Having looked at this page on RealOEM you might be in luck.
http://www.realoem.com/bmw/enUS/partgrp?id=0555-USA-07-2002-89V3-BMW-K_1200_LT_99_0545%2C0555_
Most of the parts information you need will be on this site.
25Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 12:53 pm
pinhed
pinhed
Motorbike Mike wrote:The intermediate "bell housing" may not be required-I was just writing out loud! Smile
Awesome another page book marked lol least our lass will get a load of peace and quiet while I sit on computer hahaha
26Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Tue Apr 25, 2017 1:00 pm
Motorbike Mike wrote:I've got a set a spare clock set if you're stuck.
Even better...is the K12LT is six speed?? It does bolt straight on but its not used on the K100/K1100 because the frame designed changed and the mountings don't work.....but in the Moggy that may not be an issue.
Starters and alternators are not the best located for a car BUT they are generally quite reliable especially if you look at brushes/monkey nuts/sprag clutch before outing it together. Definitely more reliable than the original.
27Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 8:04 am
pinhed
pinhed
Awesome, engine mount wise shouldn't be a problem as I'm going to make a cradle around the engine then mount it to the moggy using the exsisting engine mounts. The whole front end of the moggy is going to be a fibreglass single peace that will lift off to make working on it a bit easier and hopefully further down the line I want to turbo it if I can find enough information about the German company that did a load with turbos.
Task this week is put indicators on the front of the k100 and get it comfy and more road legal as the guy who had it before put stupid clip on bars on it and a pair of headlights with bright blue halos around them hard wired in ......... muppet to say the least hahaha
28Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 8:09 am
Motorbike Mike
Motorbike Mike
What's betting that you get to really like the K and have to get another engine?  Laughing
29Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 8:27 am
pinhed
pinhed
Hahahahahaha if I do I'm getting another K engine although I've now got a deadline to get my chopper finished as it has to be done by the time the K comes off the road I can't not have a bike 😂😂😂
30Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 8:30 am
Motorbike Mike wrote:What's betting that you get to really like the K and have to get another engine?  Laughing
Yep! like
31Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 8:30 am
Motorbike Mike
Motorbike Mike
You know I have one don't you?
32Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 9:04 am
pinhed
pinhed
I do now lol think our lass would kill me at the moment thou hahaha
33Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 9:11 am
Motorbike Mike
Motorbike Mike
Motorbike Mike wrote:You know I have one don't you?
It's easier to ask for forgiveness than it is to ask for permission.
34Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 10:10 am
I had a VFR800 Vtec parked here for quite a while.
'Dad's new bike' my son said.........
Many ways of dealing with that issue of another bike.
There's also 'that K100 came with a spares bike' that you work out why it became a spares bike and fix in a few hours.
If you need advice on this subject on the forum there is plenty of it about.
You need to break the news that the K100 you got, because its an earlier one, may not be suitable for them plan and that it would be simpler to just get another later engine and use that. Then of course when you go looking for one its cheaper to buy a whole K and ride it home rather than getting a van to collect the engine.....
35Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 10:44 am
Do it the easy way and get a K1200engine and gearbox with a reverser and drop that in. An extra 20hp and no shagging about.
36Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 10:46 am
pinhed
pinhed
92KK 84WW Olaf wrote:I had a VFR800 Vtec parked here for quite a while.
Hahahaha I like your thinking,luckily at the moment she really likes the moggy and what I'm going to do to it, she now has shown interest in the bike and been on back a couple of times. Sod's law she shows an interest when I tell her I only got it to use the engine and wiring loom.
Suppose I can always keep an eye out for another K bike and a k1200 would be perfect with reverse gear and sweet talk her saying it got it so I can keep the other one on road so we can still got out on it.
Don't think she'll be impressed when the choppers finished as it's hardtail with a single seat 😂😂
37Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 10:48 am
pinhed
pinhed
RicK G wrote:Do it the easy way and get a K1200engine and gearbox with a reverser and drop that in. An extra 20hp and no shagging about.
I'm really tempted had a quick eBay and could only find engine block and gear box separate. Sadly can't justify spending £1800+ on a complete bike just to strip although in an ideal world I would lol
38Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 11:38 am
Just tell her you are getting a sidecar for it.
39Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 2:43 pm
On the plus side, at least she can be assured you won't be gallivanting about with some strange pillion candy. Smile
40Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Wed Apr 26, 2017 4:13 pm
pinhed
pinhed
Hahahaha turning circles a nightmare on it as it is with 6" extended forks and big rake lol
Ohhhh she'll still think I'm upto something or some art lol she's female (apologies to the female members but every lass I know is nuts lol)
Was meant to do bits on the bike tonight but I ain't getting cold and wet this time of year hahaha
41Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 01, 2017 4:28 pm
pinhed
pinhed
Finally been able to get time to do somethings on the k100, removed the stupid clip on bars are riding position was horrible and pulled on my shoulder.
[url=https://servimg.com/view/19679554/5]K100 powered Morris Minor 1000 Img_1613[/url]
K100 powered Morris Minor 1000 Img_1614
K100 powered Morris Minor 1000 Img_1612
[url=https://servimg.com/view/19679554/3]K100 powered Morris Minor 1000 Img_1611[/url]
42Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 01, 2017 4:36 pm
pinhed
pinhed
Painted it Matt black 😁 Fitted front indicators and sorted the lights out so there's high and low been with no stupid blue halo round them.
Sadly though the speedo still doesn't work. I've checked the pick up on rear wheel and it's clean and cleaned the connections on the actual speedo as I read on here somewhere. Anyone got any ideas? Or is it fully broke. Everything else works as should although did get a warning light on the clocks (triangle with !) I think it was that one anyway lol
Also on the near side there's a socket just above the engine that's wired in somewhere any one know what's it's for??
Cheers again peeps
K100 powered Morris Minor 1000 Img_1619
K100 powered Morris Minor 1000 Img_1617
K100 powered Morris Minor 1000 Img_1616
K100 powered Morris Minor 1000 Img_1615
K100 powered Morris Minor 1000 Img_1618
43Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 01, 2017 5:49 pm
Are you referring to the auxiliary socket?  It's commonly used for connecting heated jackets and battery chargers
44Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 01, 2017 6:02 pm
pinhed
pinhed
Point-Seven-five wrote:Are you referring to the auxiliary socket?  It's commonly used for connecting heated jackets and battery chargers
Ahhhhhh that will be it then cheers dude.
45Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 01, 2017 6:05 pm
pinhed
pinhed
Also the switches under the ignition cover, there's one that has been cut,was there meant to be more and was it wired up as standard?
K100 powered Morris Minor 1000 Img_1620
46Back to top Go down   K100 powered Morris Minor 1000 Empty Re: K100 powered Morris Minor 1000 Mon May 15, 2017 5:26 am
I believe there is an article about fixing a flakey speedo, where by they end up dealing with the connector up near the brake reservoir on the frame tube the fuel pump connector is also there, that connector often gives trouble.
