Dai wrote:Al, I guess that you have car rims front and rear? Or just the rear? The guy I went to India with builds outfits. The last one he made he machined a Smart car wheel to fit an R100RS rear hub (or the other way round!). The rig runs car tyres on the sidecar and bike rear and a bike tyre at the front. UK legal, because he's using the correct rims.
From the little I understand, a bike tyre is better up front because it makes the steering easier. I can figure out why but I'm stymied when it comes to try and write it down!
The front and rear are custom 15" wheels, not car wheels on adapters. The rear always runs a car tyre between 135-165 wide. 155 is a nice size for width/height and slight reduction in gearing but is hard to get. 165 is the easy choice in Australia, 135 makes the engine rev too hard at speed and breaks away more easily under power (one tyre I had shredded rather than wore out)
The front wheel; I don't know whether it was made to car or bike specs. Bike tyres always fit easily, a 135 or 145/80 car tyres fit easily, a 145/65-15 Smart car tyre is an absolute bitch and takes over 70psi to make it seat on the bead, never mind getting it off.
Smart car tyre: bigger contact patch, better brakes, sharp handling(low profile), better high speed. Heavier steering, more inclined to head shake.
Bike tyre (130 or 140), smaller contact patch, brakes not as good more inclined to lock the front, less confident in wet conditions (ie must ride slower). Lighter steering, very little head shake(due to narrower contact patch), I'm not even running a steering damper now.
With the state of my shoulders at the moment, the lighter steering wins the argument for me at the moment. I did run a car tyre up front for many years and I do understand why you would, each is a compromise with their own strengths.
