1Back to top Go down   New Member Empty New Member Sun Mar 05, 2017 7:54 am
leon83
leon83
Hello, just signed in. I bought myself a K100RS 16v last year and rebuilding it.
Now searching for a little bit of help with removing the Air Cleaning Box and replacing it for Open Air Filters. But what to do with the:
- NTC (can I just mount it straight to and Open Air Filter, I bought these...Emgo Premium Power Filter)
- and suggestions for the air / oil parts of the Air Cleaning Box?
Thanks in advance.
Leon
ps.
the K looks like this now:
New Member Img_2413
http://www.leonvanzanten.nl
2Back to top Go down   New Member Empty Re: New Member Sun Mar 05, 2017 2:06 pm
Welcome to the forum Leon83.
About the installation of the air filters, I saw pictures of the conversion but don't know if this is documented on the forum. You will have to do an extensive search. Sad
New Member Frog15New Member Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   New Member Empty Re: New Member Sun Mar 05, 2017 2:40 pm
leon83
leon83
I've been searching all weekend. What I've read is that removing the Air Filter Housing isn't wise if you have a K100RS 2V but for the 4V is was possible. Only not sure what to do with the NTC. Hopefully someone can help me out.
4Back to top Go down   New Member Empty Re: New Member Sun Mar 05, 2017 2:51 pm
leon83 wrote:I've been searching all weekend. What I've read is that removing the Air Filter Housing isn't wise if you have a K100RS 2V but for the 4V is was possible. Only not sure what to do with the NTC. Hopefully someone can help me out.
On a 2V, the purpose of the air box is to give feedback to the fuel injection system.
The 2V has a Throttle position switch (TPS) feeding only info about idle or full throttle. (This is why you can disconnect it).
The 4V has a TPS feeding info about the real position of the throttle which on the 2V is equivalent to the position of the flap in the MAF.
5Back to top Go down   New Member Empty Re: New Member Sun Mar 05, 2017 3:16 pm
leon83
leon83
For the airfilters, I've ordered them. So I will try to fit them nicely. Will post photos when it's done.
Can you explain to me what your last sentence means about the TPS feeding info? (a bit of a newbie)
6Back to top Go down   New Member Empty Re: New Member Sun Mar 05, 2017 6:32 pm
Please read my write-up on the EFI toubleshooting Guide. You will understand the purpose of the Mass Airflow Sensor on a 2V and why it's not easy to remove it.
