1Back to top Go down   LED turn signals and relays Empty LED turn signals and relays Wed Feb 15, 2017 3:58 pm
jtssviggum
jtssviggum
I am planning to change my turn signals and rear tail light for new LED signals and I wanted to ask if I need to change the Flasher Relay and if there is something else I need to replace in order to get the LED lights to work properly.
Thanks..
Jan Exclamation
2Back to top Go down   LED turn signals and relays Empty Re: LED turn signals and relays Wed Feb 15, 2017 4:06 pm
BobT
BobT
jtssviggum wrote:I am planning to change my turn signals and rear tail light for new LED signals and I wanted to ask if I need to change the Flasher Relay and if there is something else I need to replace in order to get the LED lights to work properly.
Thanks..
Jan Exclamation
No all you need to do is modify your flasher relay. It is a five minute job and is free. You can then fit LEDs front and back with a normal flash rate. If you do a search on this forum for LED flashers, you should find a link to the mod, it involves cutting a tiny pin in the relay.
3Back to top Go down   LED turn signals and relays Empty Re: LED turn signals and relays Wed Feb 15, 2017 4:20 pm
Chocolate
Chocolate
Hey Jan!
There is a easy way to manipulate the relay.
I don't find the link, but somebody else will :-)
Remove the existing flasher unit, open it up, cut pin 7 on the 8 legged chip and put it back together. Works fine.
I didn't do this so wait until somebody confirms!!!
That's what I found
http://www.motobrick.com/index.php/topic,659.0.html?PHPSESSID=964b3b1aa1179546587eb1ef62880ef0
http://technik.flyingbrick.de/index.php?title=Umbau_auf_LED_Blinker
