1 Does these relays work? Tue Feb 21, 2017 12:27 pm
jtssviggum
Another question from mr. don't know it all.
Can I use the following relays? They have 8 pins (the one used in the diagram below have 4 pins). It was the only option at my local shop. It is still 12v and 1A. If I can use them, how the heck do I connect them as shown in the diagram below (since it is 8 pin not 4 pin). I guess it is a double switch below?
If you are not familiar with the topic please see the diagram below. It is for the starter (gear indicator) relay system to enable start when installing an aftermarket speedometer.
