1 seriously low compression 1986 BMWk100 Sat Feb 04, 2017 4:28 pm
wilbo
Hi guys, i'm a newbie K100 owner, purchased a non runner with electrical fault to restore during UK winter. Anyway I sorted the electrical fault in 24hrs, starter motor needed polishing up and I have the bike running, starts first time and sounds lovely! As i'm going to take frame away from engine and have it blasted and painted I thought I would do an initial compression test before I check valve clearences and see condition of engine incase I need to carry out any engine work when I have the oppourtunity.
I warmed the engine up, then carried out the compression tests and all circa 80-85psi! Does anyone think valve adjstments will make a huge improvement? I'm going to take cover off and check clearences but I am not convinced. As my bike is a 1986 model i'm thinking it maybe a leaded/unleaded valve issue on the cylinder head, any views off you experts? The bike says 42,000miles and is in good condition for 31years old,does not look like it has had a hard life but as we all know many a clock failed!
Any pointers for me??
Thanks in advance
Thanks in advance
