Go to page : Previous  1, 2
51Back to top Go down   Fuel in oil - Page 2 Empty Re: Fuel in oil Wed Mar 29, 2017 6:07 pm
Jonas Bodin
Motorbike Mike wrote:I seem to remember pointing toward the injectors on #4, #18 & #21.  Very Happy
So you did  Very Happy
The weird thing is that they didn't leak one drip of fuel when I had them out... I would have expected to see them leaking a LOT! But I will try it once again:M:
52Back to top Go down   Fuel in oil - Page 2 Empty Re: Fuel in oil Wed Mar 29, 2017 6:44 pm
Peterk100rs
Peterk100rs
So I'm new to k bikes so this problem is fresh for me . All I can say is get your injectors cleaned properly . Run some petrol cleaner through a few tanks of fuel and make sure there's no water getting in .
I had a weeks of problems similar to this and one of the issues was a injector working but not closing properly hence flooding the cyclinder. After taking them out and cleaning them and changing the o rings . I tested them under pressure and could see now they all looked like a similar spray pattern where as before one looked more powerful than the rest .
Anyway I would put my money on injectors . Mine is running sweet now after a few bottles of petrol cleaner and a few hundred miles .
Oh and just to mention I also had water in the fuel which got I through a leaking petrol cap on tank .
53Back to top Go down   Fuel in oil - Page 2 Empty Re: Fuel in oil Wed Mar 29, 2017 9:49 pm
nods
nods
This recent thread shows that a faulty ECU can pump in too much fuel.  Perhaps your ECU hasn't failed completely but is on it's way out?
Chassis number0025951
Vehicle code0504
ModelK 100 RT 84 (0504 ( 0505 )
Body typeK 100 RT 84 (0504
Production date1985 / 01
Engine0514)
Transmission
Steering
CatalyzerNONE
54Back to top Go down   Fuel in oil - Page 2 Empty Re: Fuel in oil Wed Mar 29, 2017 11:37 pm
Yep. Starting to sound like the FICU is cactus. They're normally a very reliable unit but lately we've been seeing failures giving symptoms like excessive fuel at startup. Try swapping with a known good one. Just make sure its the correct one for the K100 2V as they aren't all the same. The K100 '83 to '90 uses #0 280 000 313
Similar issue here...
WTB FICU for 2V K100RS
 Fuel in oil - Page 2 Austra12    Fuel:  95 Octane
55Back to top Go down   Fuel in oil - Page 2 Empty I think IT might be solved!? Sun Jun 03, 2018 6:22 pm
Jonas Bodin
Jonas Bodin
Hi there!
Thought I might do a followup on what has been going on with My K-bike!
I had problems with an increasing oillevel and the oil smelling fr.o.m. fuel.
As you can see, if you have followed this thread, I've done some troubleshooting whitout any luck (Thank's for all advises anyway:tu1:).
Got a tip to check the microswitch in the trottlebody. Apparently it's supposed to click when you turn the throttle just a little bit -mine didn't!
Also noticed that the gaswire was a bit tight adjusted so the throttle would never get to a fully closed position. So I slackened the gaswire and adjusted the microswitch (is it called TPS?). Have ridden around 600km since this adjustment and doesn't experience any fuel in the oil anymore!
It seems like this was the cause of my problems. Perhaps someone knows if this is a plausible explanation?
Best regards
Jonas
56Back to top Go down   Fuel in oil - Page 2 Empty Re: Fuel in oil Sun Jun 03, 2018 8:31 pm
Good to hear you're going well again. I cant figure out how that would cause the problem but strange things happen. It would however make it difficult to start.
