Number of posts : 7967
Check your throttle body balance but before you do that be sure your valve clearances are good.
Your injectors should also be good.
Something that I found made a very big difference, new footrest rubbers.
If you have doubts about your frame mounting points check them. They should be shimmed to take up all gaps before bolting up the mounts. You will need to slacken them all to do this. The mounting bolts must not be used to pull the engine and frame together, if you do that you are pre loading the frame with stresses. That's why they need to be correctly shimmed. Its easy during maintenance for shims to get lost.
1971 Yamaha 125 YAS-1
