1Back to top Go down   Can I remove the choke? Empty Can I remove the choke? Wed Jan 11, 2017 11:49 pm
nods
nods
Hi Everyone,
In looking to change handle bar controls and minimise everything, I'm wondering if I can remove the choke?  I've done a bit of reading and found out the choke is just a throttle advance, so does that mean I can just keep the revs up a bit until she warms up, or am I asking for starting problems with no choke?
Cheers,
Nods
Chassis number0025951
Vehicle code0504
ModelK 100 RT 84 (0504 ( 0505 )
Body typeK 100 RT 84 (0504
Production date1985 / 01
Engine0514)
Transmission
Steering
CatalyzerNONE
2Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 12:37 am
brickrider2
brickrider2
I've never removed the fast idle lever (choke?) so I can't answer definitively.  But, it seems to me that starting wouldn't present a problem if you did removed it.  Question: Why would you want to?  I find it convenient on my 1985 K100RS, maybe it's not so on other models.
3Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 2:14 am
nods
nods
brickrider2 wrote:I've never removed the fast idle lever (choke?) so I can't answer definitively.  But, it seems to me that starting wouldn't present a problem if you did removed it.  Question: Why would you want to?  I find it convenient on my 1985 K100RS, maybe it's not so on other models.
Thanks for that mate.  Mine's an '85 K100RT that I got recently in pieces and is not running.  I'm doing a minimalist custom and want to change the controls so it won't have the choke lever mounting point.
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
4Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 5:36 am
JGT
JGT
You could fit a friction screw to the twist grip to aid warming up.
1992 K75
5Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 5:50 am
nods
nods
k100virgin wrote:You could fit a friction screw to the twist grip to aid warming up.
True that. From what I've read the Bricks and the Jetronic don't like any throttle when pressing the starter. So as soon as she fires I guess I'll just give it a little throttle to prevent stalling.
If the choke is just a manual throttle control, there shouldn't be any harm in removing it. But I defer to the experts in case there's something more to it.
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
6Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 7:44 am
It's not a choke - it is, as you say, a fast idle lever. Pushing it 'on' opens the butterflies very slightly and the Jetronic does the rest. If you're not in a cold bit of Kangaland then you might be able to get away with it; otherwise if you want to dump the cable it should be possible to machine up a lever mechanism that mounts on the end of the TB bank. I did a 'feasibility' study once (for a special), came to the conclusion it was possible using a similar mechanism to the old Amal enriching slide but didn't follow through with the detail.
7Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 8:05 am
I've never used the 'choke' for starting in 33 years of riding K's, so I don't see any problem with it being removed.
Just my opinion.
8Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 9:34 am
I don't use the choke for starting and generally just fire up and ride off. My first 2 miles or so are downhill.
The only time I would think it would be needed is if you want/need to idle the engine at cold but the general advice for minimising engine wear is to fire up and drive/ride off but don't ride hard until engine is warmed up.
9Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 9:41 am
nods wrote:From what I've read the Bricks and the Jetronic don't like any throttle when pressing the starter.
Where did you read that, Nods?
It's useful in the cold country where I am. I prefer my bike's engine to snap into action to save wear on the relay so I use the "choke" when I  start the bike up the first ride of the day, ride away immediately and shut it down after the bike is in second gear. There are a couple of months when it might not get used at all. June and July maybe. I seem to recall watermelon involved somehow. Anyway, there seem to have been no harmful side effects. I'll report back in 33 years.
It's definitely not minimalist though. I've often thought how much more attractive my bike and myself would be without that lever sullying the graceful contour of the handlebar. Smile I just have no initiative.
10Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 11:21 am
The choke reference is only on the lever because BMW raided their parts bin for the boxers and the lever was printed 'choke' on top.
All it does on a K is apply some throttle but once you are riding and using the throttle it's doing nothing at all. Using the twistgrip to apply some throttle before you start up is exactly the same as using the 'choke' lever. Once you move off you can close it fully because the twistgrip is now doing the job. It is effectively a hand throttle rather than a 'choke'. A FIAT of 1985 vintage that I once drove had a similar feature but they referred to it as a hand throttle.
11Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 11:37 am
A throttle lock will let you remove the "choke", but it will not be as convenient to avoid over revving the engine as it warms up.  The "choke" has a fine tuning effect on idle speed that the throttle does not have.  This makes it easier to use for that morning warm up while one dons their helmet and gloves.
12Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 12:01 pm
Point-Seven-five wrote:A throttle lock will let you remove the "choke", but it will not be as convenient to avoid over revving the engine as it warms up.  The "choke" has a fine tuning effect on idle speed that the throttle does not have.  This makes it easier to use for that morning warm up while one dons their helmet and gloves.
Here we differ.
My bike gear sleeps on the Aga at night so it's nicely warmed up in the morning. I put it all on, including helmet and gloves, step outside, hop on the K, key into ignition then fire up and go. Same routine whether its frosty or warm, except Aga is off in summer.
13Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 1:23 pm
Motorbike Mike
Motorbike Mike
My first incarnation of my Flying Brick had a fast idle lever. It's a poor image but you can just see the lever mounted on the coil mounts. It kept it out of my way down there and all I had to do was make a short cable-easy. I have different TB's on now and don't actually have a fast idle option, I just open the throttle a little but as it's a track bike I do have to stand and warm the bike up before revving the nuts off it!
Can I remove the choke? Choke11
14Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 6:52 pm
nods
nods
Rick G's reply, post 5 in this thread https://www.k100-forum.com/t6232-finicky-starting
Thanks for the info on your bike and starting habits.
You would appear more attractive without the choke?  lol!
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
15Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 6:53 pm
nods
nods
sidecar paul wrote:I've never used the 'choke' for starting in 33 years of riding K's, so I don't see any problem with it being removed.
Just my opinion.
Thanks Paul.  Wow, and that's in chilly England!
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
16Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 6:54 pm
nods
nods
92KK 84WW Olaf wrote:I don't use the choke for starting and generally just fire up and ride off. My first 2 miles or so are downhill.
Sounds good to me Olaf  Smile
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
17Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 6:56 pm
nods
nods
92KK 84WW Olaf wrote:The choke reference is only on the lever because BMW raided their parts bin for the boxers and the lever was printed 'choke' on top.
Perfect, that's the confirmation I was looking for.  Thanks again Olaf.
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
18Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 7:44 pm
nods wrote:Rick G's reply, post 5 in this thread https://www.k100-forum.com/t6232-finicky-starting
The average temp. where Rick lives—although undoubtedly he has worldwide experience—is 29ºC and the average where I live is 6.6ºC so I'll just stick with what works here, which is probably a reasonable strategy regardless of where the bike and its owner reside. As far as "chilly old England goes" wherever they can have 6" of snow on the ground in October that keeps accumulating until finally its gone in mid-April, I might give their method a try.  cheers
I can't risk removing the choke and creating waves of resentment.Laughing
19Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 8:14 pm
Jan av Max 26.5°  July av Max 14.0°
          Min  15.6°            Min  1.3°
Stanthorpe is in the Southern Highlands of Queensland and that 29° is for Brisbane which is sea level.
My K100 which I no longer own would not fire if you gave it even the slightest throttle and temperature had no bearing.
Some Ks are very finicky about it while others not so much.
Almost all EFI engines the manufacturer will say no throttle at start up, let the electronics do the thinking. Not sure I really trust that it sounds like something a government would say. Very Happy
20Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Thu Jan 12, 2017 8:32 pm
nods
nods
RicK G wrote:Jan av Max 26.5°  July av Max 14.0°
          Min  15.6°            Min  1.3°
True they do say that, although with my 2012 modern EFI Tiger it helps to just have the throttle cracked open a tiny bit for the cold morning starts when it's freezing or just below.  It starts much easier with that little trick, and that's pretty much universal for that bike according the forum.
Vehicle code0504
Engine0514)
Transmission
Steering
CatalyzerNONE
21Back to top Go down   Can I remove the choke? Empty Re: Can I remove the choke? Fri Jan 13, 2017 8:00 am
Gauntlett
Gauntlett
not fitted to my trike since 1996, starts no problem, slight throttle listen for the click of the position sensor, then hit starter and away you go.
