Number of posts : 7967
As Dai will point out the Brembo brake calipers on the K100 are shared with the Guzzi which may be a good starting point. The same calipers are also shared with some of the R models but left becomes right as they are mounted the other way round. Not sure about the master cylinders but I suspect that this may be a route to go as the braking forces on each wheel may not be radically different. Getting it signed off may be a problem.
BUT I DO NOT fancy linked brakes for riding in ice or extreme gravel when at best you need the option of zero brake force on the front wheel. Many years back a very kindly man would take us riding our bikes on mud and oiled surfaces to get us the feel of bikes in such conditions and how to keep them upright or let them down slowly to minimise damage to oneself or the bike. Extreme careful use of the throttle on power and engine braking and complete non use of front brakes was the order of the day and very little use of the rear. Not a chance you could do that with linked brakes, front wheel may well let go first.
Roundabouts and car parks over here can be heavily contaminated with diesel spillages, use of the rear brake is great for getting the K to drop into the tight curve, relearning this could be scary as I would never use the front brake in such a location in wet conditions when you see rainbows on the surface!
Having a complete K100LT with ABS in my shed I think the idea of adding ABS would not be impossible but would have to be extremely methodical and IMHO I would only attempt it as a transfer from one working bike to another. Wiring is 'fun'.
1971 Yamaha 125 YAS-1
