1Back to top Go down   Starter button bypass  Empty Starter button bypass Tue Dec 27, 2016 5:49 am
cliverocky
cliverocky
Going to install a temporary starter button on the RS until my replacement turns up.
How do you pull the wires out of the terminal block (male side)?
2Back to top Go down   Starter button bypass  Empty Re: Starter button bypass Tue Dec 27, 2016 6:57 am
You either need the correct tool or a piece of tube that fits EXACTLY over the pin. That will compress the locking ears at the back and allow you to pull the pin out.
3Back to top Go down   Starter button bypass  Empty Re: Starter button bypass Tue Dec 27, 2016 11:41 pm
I think it might be possible to install a temp starter bypass between the starter relay control coil and one of the fuses. That would be a lot easier. Someone with a wiring diagram might be able to confirm that and give the correct connections. I'm on-the-road atm and don't have anything like that with me.
 Starter button bypass  Austra12    Fuel:  95 Octane
