1Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Mon Nov 14, 2016 7:22 pm
G'day All, seem to be having a lot of clutch/gearbox related issues lately. Pulled the clutch out of the 'good' 75 and found the splines kaput in the driven plate. This also means that the splines on the gearbox input shaft have been damaged. Does anyone out there have a good input shaft for sale?? Please let me know. Thanks Tom
2Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Mon Nov 14, 2016 11:57 pm
G'day All, an input shaft is on the way. Thank you all for looking. Cheers Tom
3Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Tue Nov 15, 2016 1:50 am
good to hear tom
yeah its a shame when they do that ...similar happened to me not so long ago
I hope you have also solved the rumble from the gearbox - drive shaft when this all goes forward ...perhaps new bearings in the gearbox ?
cheers mate
4Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Tue Nov 15, 2016 8:06 am
You've certainly been clocking the hours up on those Ks of yours Tom. You should be able to R&R the back end of a K in your sleep by now. Good luck with it mate. Cheers
 Tom's K75 Final Drive Austra12    Fuel:  95 Octane
5Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Tue Nov 15, 2016 8:00 pm
Thanks for reply Charlie and Nigel. I have (just about) all necessary clutch bits to hand so installation of clutch will soon be complete. I may fit the spare gearbox and if that works out to be OK, will install the input shaft ( on the way now) into the original gearbox as well as replacing all bearings and seals. This will get the bike on the road a bit sooner. This whole issue is giving me nightmares and I may be edging closer to giving up on the Ks. Cheers Tom
6Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Tue Nov 15, 2016 8:02 pm
Don't go to the dark "R" side!
7Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Tue Nov 15, 2016 10:46 pm
Rickmeister
Rickmeister
Hey! It's only a slip of the pen from"K" to "R"!!
8Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Tue Nov 15, 2016 11:00 pm
Thinking about the "F" side.
9Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 12:04 am
You blokes must have eaten too much alphabet soup when you were younger.
10Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 4:01 am
just do the sensible things tom ...old bikes rumble and groan ...  and the k bikes just keep on going given the right lubrication time to time
good luck mate
11Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 4:24 am
Our garage has R, F, KKK
I think I need to buy a vowel.
'93 K1100LT
Tom's K75 Final Drive K-dogs10
12Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 8:58 am
Tom's K75 Final Drive 112350 Tom's K75 Final Drive 44271
13Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 9:30 am
How about a Ural
14Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 3:45 pm
Remember H and D are banned.
15Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 4:42 pm
ainsjac wrote:Remember H and D are banned.
I've had a some H's, but only one good one.  Nearly bought a D once.
'93 K1100LT
16Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 4:53 pm
Sorry, both letters must be used together.
17Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 5:31 pm
ainsjac wrote:Sorry, both letters must NOT be used together.
18Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Wed Nov 16, 2016 6:03 pm
Hardly Desirable.
19Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Wed Nov 16, 2016 8:26 pm
How about a vowely Ossa which was apparently Rickmeister's prize possession a little while ago.
20Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Thu Nov 17, 2016 2:08 am
Rockman
well, my garage goes KRTKLRKLRRRTGTX7, no H or D here
21Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Thu Nov 17, 2016 5:05 am
That is a great smattering of the alphabet soup.
22Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Thu Nov 17, 2016 6:59 am
Hmmm.... mine currently goes MGMGMGSK.
23Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Thu Nov 17, 2016 8:53 am
Mine goes K; it's an easy-for-me-to-remember psuedo-palindrome.
24Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Fri Feb 03, 2017 12:45 am
hi tom,
just thought to post a pic of my noisy bevel box
I should have done it before .
the main bearing once cleaned of oil is quite noisy .when taking just the weight of the output shaft ,   and you can see the scoring on the bearing surface of the other end
I'm just pulling it apart for inspection before the Karuah run as the seal on the output (the big one ) is still weeping
I'm going to re-linish the running surface and shove it all back together  and relocate the seal , till I can afford replacement bearings,  as there is likely a tiny bit of movement
reminder this bevel box sat for really long time before I got it , and suspect that there may have been some  corrosion - pitting on the bearing race faces
 Tom's K75 Final Drive 20170210
Tom's K75 Final Drive 20170211
25Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Fri Feb 03, 2017 3:57 pm
Hi Charlie, thanks for that info on the bearing. I haven't done a thing to mine yet. I have just fitted the one I got from Rick. I'm still in the process of fitting the Gearbox to my 75 after all the clutch issues. May have it going this weekend. My mechanical skills are a bit lacking. Might see you at Karuah. Cheers Tom
26Back to top Go down   Tom's K75 Final Drive Empty Tom's K75 Final Drive Sat Feb 18, 2017 5:38 pm
G'day All, just a quick update on the 75. Fitted a new clutch assembly, another driveshaft and a replacement final drive. Replaced the g/box input shaft and input shaft seal. Had difficulty mating the g/box to the engine even after using the alignment tool and an old input shaft with push rod. Tried a few times without success. The F800GT and the Honda VFR800X were starting to look pretty good.
Smithy came down last weekend and said 'let's have a look at that gearbox'. He took off the box, loosened the clutch cover bolts, realigned the clutch plate and bingo. The problem was that the push rod did not quite line up even after using the tool.
The 75 is now going great and thoughts of another bike have all but disappeared.
The next thing to do is repair the original FD
Thanks to Rick and Smithy for their input.
Cheers Tom
27Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Sat Feb 18, 2017 8:37 pm
good to hear tom ....ride well mate
28Back to top Go down   Tom's K75 Final Drive Empty Re: Tom's K75 Final Drive Sun Feb 19, 2017 6:30 am
Great result Tom - that was a good job to take on and it was really useful for you to share your experience.
Many lessons learnt too - particularly that (on these older bikes) it is often not just one problem, but a combination of wear in several components that present the symptoms - if you fix just one problem, the others often rise to the surface in a most frustrating way. Excellent help from Smithy too - nothing beats a little hands on experience and encouragement from someone that has done the job before to make that final little tweak that makes all the difference.
Enjoy the ride (when it's cool enough to enjoy) - you've learnt it.
Tom's K75 Final Drive Uk-log10 Tom's K75 Final Drive Sco-lo15
                              Paul  Tom's K75 Final Drive 905546712
