germanbikes
germanbikes
Hi all. I just bought a 1985 K100RT with 145K km and heavy maintenance records. It's dolomitgrau metallic and has hard bags. It's going to be my "working in Edmonton" bike. I have a 1977 R100/7 that is my summertime bike in British Columbia, along with a 1959 Zündapp Bella 150 (hence the username "germanbikes"). I look forward to learning from the old hands and experts on the forum, as I am sure to need help!
2Back to top Go down   Hello from Edmonton, Alberta and Victoria, BC Empty double island boy Sun Sep 11, 2016 9:27 pm
nvboy
nvboy
Greetings from Nanaimo!
Saltspring?  Do you ever get your bike out of first gear?
Welcome to a great forum for your great K bike.
nvboy
Hello from Edmonton, Alberta and Victoria, BC Can-lo10
Chocolate
Chocolate
Welcome here!
Enjoy your bike.
Looks like a nice place where you live.
I hope you go sailing.
Cheers from germany
Hello from Edmonton, Alberta and Victoria, BC Saltspring-island-slideshow-ganges-aerial-gulf-islands-british-columbia
Brad-Man
Brad-Man
Welcome!
Hello from Edmonton, Alberta and Victoria, BC Usa-lo10
5Back to top Go down   Hello from Edmonton, Alberta and Victoria, BC Empty thanks Fri Sep 16, 2016 12:56 am
germanbikes
germanbikes
Thanks, all, for the greetings.
The K100 is in Edmonton, where I work. I have an R100/7 on Salt Spring, as well as my Zündapp scooter. But we are moving to Victoria (family reasons) soon, and those bikes will end up being used on Vancouver Island/around town.
Hope to see more Canadians here, esp. on the west coast--
Tomorrow the K100's fuel pump goes back into a cleaned fuel tank with a new pump screen, filter, and hoses. Crud build-up in tank stopped the pump on my ride home from picking it up! It seems to pump fine now, after cleaning.
Hi GB. WelKome to the forum from the Land Downunda.
I had the same problem on my recently purchased '88K100RT bought as a non-runner. Had to replace everything inside the tank and give it a good clean out. The best thing to clean gunk out of a tank that's been sitting for ages is a laundry Oxy cleaner with active ingredient: sodium percarbonate. Like any of your laundry soakers or nappy treatments etc. Mix it fairly strong. 50g/lit of warm water. Let it soak overnite and repeat if necessary.
If the tank was that bad that it stalled the engine then I would suggest you need to pull the injectors and give them a clean also and replace the kit.
Do you have any pics of your rides to post.
 Hello from Edmonton, Alberta and Victoria, BC Austra12    Fuel:  95 Octane
7Back to top Go down   Hello from Edmonton, Alberta and Victoria, BC Empty pix Mon Sep 19, 2016 2:05 am
germanbikes
germanbikes
Hello from Edmonton, Alberta and Victoria, BC Img_0410
Hello from Edmonton, Alberta and Victoria, BC K100fr10
Washed, finally, and half-way presentable. 200 km so far; used just under 12 litres. Bike cost CDN$1,300 plus $250 in parts and fluids (so far). Needed in-tank hoses, pump screen, thorough tank cleaning, all oils. Next: brake fluid, coolant, splines. Runs like a top!
8Back to top Go down   Hello from Edmonton, Alberta and Victoria, BC Empty Final repairs finished Thu Oct 06, 2016 2:25 pm
germanbikes
germanbikes
My RT is now running properly, brake fluid has been changed, and the 'temperature switch' (which includes the fan relay) has been replaced with a new unit from BMW ($$$). Popped the new switch in today and after idling for eight minutes, the fan went on like it is supposed to. So all systems are go. There won't be much more riding this fall in Edmonton, I imagine, so spline lube and coolant flush can wait until the start of riding season in 2017!
1990k75
1990k75
WelKome to another CanucK  cheers
Past bikes - Yamaha YL-1, Honda XL-125, 1967 BSA 650 Lightning
Current - 1990 K75RT (in drydock) & 1995 K75RT VIN # WB1056503S0372669
            - 2011 Suzuki V-Strom 650
            - 2011 Yamaha XT250
Who sez I'm too old to ride?
club_c
club_c
Greetings sir!
1988 K100RS SE VIN 01477554
