1 85 K100 won't shut off Wed Nov 02, 2016 11:51 am
xASmith88x
I have been having an issue with my 85 K100 not shutting off via key or kill switch. The only surefire method is pulling fuse 1. I can stall it out, but would rather not use that as a fix.
I have checked the FI relay and it is good, the starter button is not stuck and the ignition switch is clean.
I did setup an acewell 2853, but I ensure everything was connected properly.
The bike runs perfectly without the key, I could probably go for a ride with the key out and it switched off...
