1Back to top Go down   K1100lt (92) seat woes Empty K1100lt (92) seat woes Fri Oct 28, 2016 10:35 am
DeRodster
DeRodster
Hi Inge & all
 I decided to get a secondhand seat to tie me over while I had my own recovered.
All ok so far, seat arrived in good condition and I proceeded to fit.
Problem turned out to be lower rear mountings and the front one was slightly different also
My seat has the numbers in white 2323318 4113 and on the base 52.53-2 309.860 A
Replacement has in white 2324048 1233 and 52-53-2.307.589
not a lot I can do except return it and hope they can supply correct one for my K, but wonder which machine the one I received is off ?
Over to the expert (s)
adios
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Fri Oct 28, 2016 11:02 am
589 , is this possibly a late model K100LT.  ie; 1989
K1100lt (92) seat woes 10_x_110
3Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Fri Oct 28, 2016 11:18 am
BobT
BobT
Just put the part numbers into the box on the realoem website and it will tell you exactly what models each part number is for.
4Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Fri Oct 28, 2016 11:40 am
DeRodster
DeRodster
Thanks BOB T
I did and it tells me I got a later one.
Thanks for the tip re RealOEM, handy to know
I'll contact the shop and see if I can get bracketry to suit the seat and my machine
fingers crossed, coz i really could do with not having to return it
adios
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Sat Oct 29, 2016 5:10 pm
Is there any chance you can just swap the hinges from the old seat to the new?
6Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Sun Oct 30, 2016 12:43 pm
yep that works
KKlompy K1100lt (92) seat woes 2854237993
K1100lt (92) seat woes Au-log10
7Back to top Go down   K1100lt (92) seat woes Empty Re: K1100lt (92) seat woes Tue Nov 01, 2016 12:00 pm
DeRodster
DeRodster
Problem solved...hopefully
Hi All,
 So it seems my seat was current up to 03/1993 and then BMW moved to a rubber mounted bracket
The individual seat mouldings are quite different so I really do need the correct bracket.
In any case Motorworks have come up trumps, and are forwarding the appropriate brackets as I type.
That saves me (and them) time and money sending the seat back etc etc
So all things being equal I'll have her up and running by the weekend
adios
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
