1Back to top Go down   K100 Compression Pressures Empty K100 Compression Pressures Tue Jun 01, 2010 8:22 am
mitcher9
Obviously too much time on my hands, as checked the
compression pressures on my newly acquired 1984 K100RS with 70k registered miles.
The Haynes book states 135 to 145 psi is “normal” and over 145psi is “good”. My bike measures 195psi on cylinders 2, 3
& 4 and 190psi on 1. Engine starts and runs well with no pinking etc.
Question; are the Haynes figures correct and if they are, do I need to think
about de-carbonising the head?
Any experience or advice gratefully received.
Cheers, Robert
K100 Compression Pressures Icon_study
2Back to top Go down   K100 Compression Pressures Empty Re: K100 Compression Pressures Tue Jun 01, 2010 6:53 pm
Less than ten psi variation between cylinders is not enough to worry about, nor is what some would consider a 'high' reading. If it doesn't smoke (beyond the typical sidestand start-up cloud), doesn't make strange noises, runs down the road with ease and puts a smile on your face, no worries. Haynes is talking about the normal range for infernal combustion engines. Ours are not even close to 'normal'. As the sage said, if it ain't broke don't break it.
3Back to top Go down   K100 Compression Pressures Empty Re: K100 Compression Pressures Wed Jun 02, 2010 3:50 am
mitcher9
Two Wheels Better wrote:Less than ten psi variation between cylinders is not enough to worry about, nor is what some would consider a 'high' reading. If it doesn't smoke (beyond the typical sidestand start-up cloud), doesn't make strange noises, runs down the road with ease and puts a smile on your face, no worries. Haynes is talking about the normal range for infernal combustion engines. Ours are not even close to 'normal'. As the sage said, if it ain't broke don't break it.
Many thanks for the advice. Will keep riding and smiling. All the best, Cheers
4Back to top Go down   K100 Compression Pressures Empty Re: K100 Compression Pressures Wed Jun 02, 2010 3:30 pm
TWB has nailed it don't worry just enjoy!
