1Back to top Go down   Wheel rim size Empty Wheel rim size Mon Oct 17, 2016 7:45 pm
smoll1
Hi all
I have the black style wheels with the flat edge to spokes. It's a black rs style model.
Bent the rim in pot hole last week. None listed for sale. I noticed some k75 had these style wheels.
Does anyone know if they are same size?
Smoll Very Happy
2Back to top Go down   Wheel rim size Empty Re: Wheel rim size Mon Oct 17, 2016 8:09 pm
kioolt
kioolt
A way for you find out for yourself would be to goto realoem.com.  Lookup the wheel on your bike.  Once you find the wheel you can click on the part number.  A list will come up showing all bikes that that wheel is used on.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
3Back to top Go down   Wheel rim size Empty Re: Wheel rim size Mon Oct 17, 2016 8:25 pm
The BMW rims are much softer than the Jap alloy wheels and can be knocked back into shape quite easily. Of course it doed depend on how bad the damage is, if it's cracked or creased or wont hold air it's not salvageable.
I use a rubber hammer or a piece of soft wood and a 16oz hammer and slowly work in from the extremities of the dent.
4Back to top Go down   Wheel rim size Empty Wheel rim size Tue Oct 18, 2016 4:14 am
smoll1
Aah yes thanks
I checked the real OEM and says same size rim. 250x18 so that looks promising.
It was pretty bad bend. I knocked back in with mallet as suggested. It is better buy can get right and steering shakes a bit now.
Hopefully now they appear same I can sort one out.
It appears the rear is different, depending in whether a drum brake or disc and different size.
5Back to top Go down   Wheel rim size Empty Re: Wheel rim size Tue Oct 18, 2016 6:21 am
mike d
Alf Hagon in London also repairs cast wheels - bit far from you, so postage may be expensive.
Mike
