Number of posts : 7967
Starter is very easy to remove on the K100LT, whether it has ABS or not. Did it a few times on my K100LT and it came off in 10 minutes.
Remove the tray under the seat, you also have to unplug and take out the Fuel Injection Control Unit which is in a slot in it, take out the battery, take off the plastic cover over the coils. I can't remember if I had to take the coils out but I took them out anyway to clean the connections while I was at it. They come out easily. You will see a 10mm nut on top of the starter, that's the electrical connection, you will see 2 6mm[?] Allen bolts towards the back where it's bolted down on to the gear box. It should then lift very slightly and come out backwards towards the rear wheel. Only 2 long screws hold it together too. That's as much as you need to do IF it's the starter motor only and you are cleaning it, replacing brushes or whatever.
All of the relays including the starter relay and the load shed relay [LST] are in the electrical box under the petrol tank so to get at those a dealer will have to take the tank off. But that only means taking off the black leg panels and both left and right hand storage boxes and probably the left lower panel and the two baffles in there so they can access the fuel lines at the left front of the tank to disconnect them. You can modify your K by putting longer fuel lines in so you can access this electrical box without removing the tank BUT the storage boxes/leg panels will still need to come out to allow you to life the rear for access to it.
The thing about taking K to a dealer is they don't have people who know them. To some they look complicated and a sea of plastic that must be removed to do any simple task. Nothing could be further from the truth. Try changing spark plugs on a Japanese four, my son's bike takes over an hour, on a K its a 10 minute job. You have to take out the camshafts just to check the valve clearances, on the K you check in situ on the 4 valve and only take them out to adjust them. For many of the maintenance items on the K only the 2 lower panels and the boxes/leg panels and baffles come out and with a bit of practice those are very fast operations. These are also designed to come off like this, without needing to take off the rest of the fairing. For a service, if you have lengthened the fuel lines, you can access the radiator cap without removing the tank to refill the cooling system. I have only once taken off the panel around the radiator and all the small bits there and that was for a head bearing job that was a bit pear shaped. The main part of the fairing doesn't need to come off at all.
Do you have a Clymer or Haynes manual? I have the Clymer and its very useful for understanding how these things are done even if you don't actually do them yourself. But the best place for anything is the forum!! Even if no one is near you or its a difficult task someone will give you good pointers.
1971 Yamaha 125 YAS-1
