1 Gear Box/Drive Shaft Noise Sat Oct 01, 2016 8:12 pm
G'day All, I need some advice from more knowledgeable forumers than myself. Have recently installed a new clutch plate into the recently acquired 75S. Installed the gear box, started it up to check for any untoward noises going through the gears - none. Then installed the swingarm, drive shaft and final drive. Started the bike up and there is a rumbling noise from the uni. joint area through all gears. Remove drive shaft, no rumbles. I suspect it is the uni. joint. Any advice welcome and thank you in advance. Cheers Tom
