Bumblebee
Bumblebee
My K100RT came from the factory with knee pads on the tank.  For the last 20+ years my knees have been uncomfortably banging into the fairing.  Had a chance to ride another K100, same everything, just no knee pads.  Knees fit comfortably into the faring pockets.  So as soon as I was home I removed the kneepads with a pair of vice grips.  They were stuck on and I do mean really stuck!
This is what the tank looked like after kneepad removal.
Removing glue from the tank after knee pad removal 20160910
To remove the adhesive I tried several things.  Nothing really worked.  I had decided I would need to repaint the tank.  At the automotive paint store we were trying to match the "Stratus Gray" BMW color without much luck.  The clerk asked what was wrong with the tank, I showed him, he said you don't need to repaint that.  Then handed me this:
Removing glue from the tank after knee pad removal 20160912
Went home, read the instructions, put it in the drill -
Removing glue from the tank after knee pad removal 20160913
And in less than 15 minutes I had this:
Removing glue from the tank after knee pad removal 20160911
It removed all the glue (rubber cement) without a trace!  All the "debris" you see on the bike is the leftover glue and residue from the media wheel.  Took it outside and blew all the debris off with an air hose - unbelievable, removed the glue without a scratch to the paint..
Removing glue from the tank after knee pad removal 20160914
3M Adhesive Eraser Wheel P/N 06612.  $35 USD.
Hope this helps someone out.
- John
http://Bugsmashers.org/phpbb
Thanks mate...I almost wish I had some adhesive I want removed...great job.
KKlompy
KKlompy Removing glue from the tank after knee pad removal 2854237993
Removing glue from the tank after knee pad removal Au-log10
eye agree klompy
great job
.........or here in Oz we would get some Eucalyptus Oil on a rag and do the same. Works a treat on all adhesive residues that I have tried it on.
Your tank looks great and I'm sure that additional extra space for your knees makes all the difference.
Bumblebee wrote:Went home, read the instructions, put it in the drill -
Unusual approach Bumble, we don't tend to go for the instructions.... not straight off anyway.
Looks like a good solution to sticky problem.
I didn't know something like that existed.
 Removing glue from the tank after knee pad removal Austra12    Fuel:  95 Octane
At home we are using a good product call Goo Gone
This is very cheap and can be found everywhere (Walmart, hardware store,....).
I used it to remove stickers on the car and it doesn't affect the paint.
Removing glue from the tank after knee pad removal 212001
Removing glue from the tank after knee pad removal Frog15Removing glue from the tank after knee pad removal Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
kennybob
kennybob
LOL--spit coffee all over keyboard...
Brad-Man
Brad-Man
WD-40 works for some adhesives...
Removing glue from the tank after knee pad removal Usa-lo10
9Back to top Go down   Removing glue from the tank after knee pad removal Empty Goo-Gone Sat Sep 10, 2016 1:20 pm
Bumblebee
Bumblebee
I first tried Goo-Gone, that worked a little, but not really well enough to get the job done. Also tried WD-40 and a few other slimy poof can products like Tri-Flow.  Bzzzt.
I was about to give the motorcycle a make-over, even considering replacing the fairing with an RS, this would be an Easter-egg hunt finding all the parts, then repainting everything.  All it took was removing the knee pads, feels great now.
So, now you know what worked for John.
