Number of posts : 7967
Its a tank off job.
If you haven't taken the tank off before or never taken one off a motorcycle before hold off until someone pops up instructions for the K1100RS.
I have taken tank off K100RT and K100LT and they are probably fairly alike in that some fairing parts come off these and probably also on the K1100RS. Its not difficult but just needs thought. The fuel lines need disconnecting and if they are perished or hard they may split. With tank off give a thought to replacing them with longer ones. They may well be original and held on with the factory clips which are a pain in as*.If possible have as little fuel as possible in the tank. You have an electrical connection too, for fuel pump and gauge wiring.
You will need somewhere soft to lay the tank and be careful of the tank spigots that the fuel lines go on to. If abused they can break.
Space is limited so you do come up from the rear as Duck says. When you are done make sure everything works after before you refit the tank.
Clutch cable does not come with the top nipple and there is also a nylon sleeve for it. You need these separately and keep the old nipple as a spare taped up in the bike somewhere, maybe inside the relay box.
1971 Yamaha 125 YAS-1
