1Back to top Go down   K75 shock on a k1100  Empty K75 shock on a k1100 Thu Jun 30, 2016 4:40 am
Johnny kidd
Johnny kidd
Hi all, I recently bought a k1100. It's driving fine but I find I an getting backache after longish rides, I notice that the suspension is very hard over bumps. I have adjusted the rear shock but it's still affecting my back.  I am wondering if the 13" shock from my k75 will fit the k1100, the k1100 shock is 14". I am 5"11 and weigh just over ten stone. Is this usual for the k1100 rear suspension to give people these issues?
2Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Thu Jun 30, 2016 5:41 am
Hi Johnny
Not sure about that one but at 10 stone you don't qualify as a Harley rider so it should not have much preload on if you have got a standard BMW rear shock on the K1100. The K1100 shock I presume has preload options but possibly you have some other issues with it.
If you are doing a replacement I had a K1100 rear shock in my possession some months back, to put on the K100 as a temporary measure. It would apparently fit so presumably the K75 will fit yours. The difference in length on the K75 unit will leave your rear end sitting a little lower and will alter the handling but I expect it will be softer.
Have a look at YSS rear shocks. I got one for the K100RT and very impressed with it. I have very little preload set up in it and increased it a little for carrying the camping gear. It as a vast improvement.
However also do have a look at your handlebar positioning, consider bar risers.
3Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Thu Jun 30, 2016 7:08 am
Its the spring and compression damping that will make the ride harsh. The best shock I have used is the RAM from http://www.realmengineering.com/page15.html
A K100/75 shock will not solve the problem, they have basically the same characteristics just that one is 30mm longer.
4Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Thu Jun 30, 2016 10:12 am
Johnny kidd wrote:Hi all, I recently bought a k1100. It's driving fine but I find I an getting backache after longish rides, I notice that the suspension is very hard over bumps. I have adjusted the rear shock but it's still affecting my back.  I am wondering if the 13" shock from my k75 will fit the k1100, the k1100 shock is 14". I am 5"11 and weigh just over ten stone. Is this usual for the k1100 rear suspension to give people these issues?
are you riding an RS or an RT? What's a "longish ride"?
An RS may give you back problems because the bars are much lower.
Lowering the rear with a shorter shock would only benefit someone with shorter legs.
 K75 shock on a k1100  Austra12    Fuel:  95 Octane
5Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Thu Jun 30, 2016 5:46 pm
Johnny kidd
Johnny kidd
Thanks for the replies lads much appreciated,  I adjusted the preload today and now I have working rear suspension  Laughing
I find the ergonomics on the k1100lt which is the model I bought a lot tougher on my back and knees than my k75s, time will tell Wether I keep it or not.
6Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Thu Jun 30, 2016 6:18 pm
The 75's do have a 'softer' spring than the 100's, with a wire diameter of 9mm compared to 9.86mm.
Just a thought.
7Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Fri Jul 01, 2016 5:01 am
possibly and likely ... the shock is cactus
I changed my rear shock to something different ..... and an amazing difference was noticed straight away .
so possibly ..like all old bikes, the replacement might be a good thing regardless of the height differences
8Back to top Go down   K75 shock on a k1100  Empty Re: K75 shock on a k1100 Fri Jul 01, 2016 5:44 am
sidecar paul wrote:The 75's do have a 'softer' spring than the 100's, with a wire diameter of 9mm compared to 9.86mm.
Just a thought.
Thanks Paul, that's a very useful bit of information for lighter K100 riders. I have very little preload on the YSS shock I am now using, started off with zero and have only adjusted twice, first was to set up for myself, then a second one for camping trip with all the gear on but still very little preload used.
