Number of posts : 7967
Hi Johnny
Not sure about that one but at 10 stone you don't qualify as a Harley rider so it should not have much preload on if you have got a standard BMW rear shock on the K1100. The K1100 shock I presume has preload options but possibly you have some other issues with it.
If you are doing a replacement I had a K1100 rear shock in my possession some months back, to put on the K100 as a temporary measure. It would apparently fit so presumably the K75 will fit yours. The difference in length on the K75 unit will leave your rear end sitting a little lower and will alter the handling but I expect it will be softer.
Have a look at YSS rear shocks. I got one for the K100RT and very impressed with it. I have very little preload set up in it and increased it a little for carrying the camping gear. It as a vast improvement.
However also do have a look at your handlebar positioning, consider bar risers.
1971 Yamaha 125 YAS-1
