Number of posts : 4461
Having dealt with more than my fair share of Ks, I long ago reached the conclusion that those needle bearings on the clutch arm pivot rod really aren't needed. More often than not, when I deal with a used K tranny those bearings have long since seized up to the point where that rod is frozen in place and I need to pound the the pivot rod out with a nail set and small sledge hammer. Why those little needle bearings don't matter is that once that rod has seized up the clutch arm still rotates freely on the "exposed" parts of the rod. That said, whenever I do a spline lube I do pull the rod and put some fresh marine bearing grease in there on the theory that it can't hurt.
