1 The bike had a little lie down, and now it won't start. Thu Apr 14, 2016 5:20 am
RussK100
Hello everyone, physics finally defeated me yesterday evening and I managed to let my K100 RT go down at about 0.5 miles per hour in a car park whilst manoeuvring into a space when I probably should've followed the standard BMW protocol of just parking wherever.
She went down gently on her right hand side (visible damage came to a big scuff and small crack on the fairing which I was naturally gutted about) and being generous was probably running for about six or seven seconds before I hit the kill switch. I righted the bike, put it on the side stand so it was leaning the other way and bought some dinner.
Came back out and she'd fire up but then just splutter for about three or four seconds then die. Toolkit out, checked the plugs and they weren't oiled and looked quite healthy. Plugs back in, cranked it over and quickly removed number one again and it was damp so spark is looking likely although not certain and fuel seems to be getting in there, possibly not enough though? Fuses are all fine. How noisy are the fuel pumps on these bikes as I can't hear much with the filler open whilst cranking and is there anything that I may have dislodged in the tank whilst tipping it over? The only thing that looks a bit suspect is a black rubber hose in the rear left of the tank at the bottom but there's nowhere obvious that it could go so I'm assuming it's a pickup, or are the pickups metal? I had thought it might be that the fuel pump had stopped being submerged whilst it was over and air had gone into the pump but I'd have thought that'd clear after a bit of cranking. I guess it could've killed a weak pump though but I thought I'd ask the experts (that's you lot!). Also, does anyone know of anything electrical around the lower right hand side fairing that I might have damaged underneath?
After a couple of hours of tinkering and Googling the starter was sounding weak as the battery slowly exhausted itself and it began to rain so I bit the bullet and called a recovery company so the bike's back at home in the garage. Put her on charge overnight and tried starting her again this morning and it's the same story, she cranks but doesn't fire or run.
Any suggestions would be greatly appreciated!
Cheers,
Russ
Cheers,
Russ
Lurking in the garage: 1986 BMW K100RT & 1991 BMW E30 M52 converted 318iS
