1Back to top Go down   Vibrations  Empty Vibrations Wed Apr 27, 2016 6:55 pm
Ian Drinky
Ian Drinky
Surprised-o: Surprised-o:
Hi guys, after riding for about a hour I find my right hand getting a tingle feeling in my right hand due to a vibration through the handle bars, any had this happen ?
2Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 7:06 pm
There have been quite a few threads on vibrations.
Check out bar end weights, they do make quite a difference. Make sure you have them in place.
Check out your throttle mechanism that is clean and well lubed so it doesn't need much effort. Consider one of those devices that allow you to keep throttle open without gripping it tightly.
Make sure grips are good and not too old.
Make sure front wheel is well balanced and running true.
Are you happy with the angles of the levers and handlebar angle/position. Lots fit bar risers.
After that its down to making sure engine is right as in injectors, balanced etc.
3Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 7:09 pm
Chocolate
Chocolate
Ian Drinky wrote:Hi guys, after riding for about a hour I find my right hand getting a tingle feeling in my right hand due to a vibration through the handle bars, any had this happen ?
Hey!
Same issue with my right hand, even the fingers are getting white, no bloud in the fingers.
I'm testing this Throttle help 1€ eBay, I'll see how it works
Vibrations  Image10
4Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 7:18 pm
That's the one!
But also do check out the throttle operating mechanism in the twist grip. It uses a chain which works well and smooth provided the mechanism and the cable are in good order.
Important to clean it out occasionally and re lubricate it. Makes quite a difference.
5Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 7:40 pm
Chocolate
Chocolate
Thanks Olaf!
I'll have a look, last time I had a look there was enough grease.
P.S.: how is the Franciscan Well doing :-)
6Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 7:50 pm
Corkboy
Corkboy
Vibrations  Image10
I have one of these and they are the business on the LT.  It means that you use the palm of your hand to keep the trottle open and can have your fingers loose.  i swap it between my transalp and Lt, and wouldn't be without it.  I sometimes adjust it (by twisting it around the grip) so that it is in the best position (normally parallel with the ground) depending on my average speed.  For example, it would be initially higher for motorway work so it's level at 100kmh, but would be initially lower for back road work.
Did I mention that it is the best thing ever  Very Happy
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
7Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 9:11 pm
Viper357
Viper357
Hi Ian
I suffer from the same thing - it seems to go away after a bit. Helps to have a CrampBuster or the throttle friction screw and give your hand a shake
1985 BMW K100RS
8Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 9:32 pm
Here is another option.
Grip Puppies
I have had a pair on my K1100 for a few years, initially bought not for reducing vibration (which they do) but to increase the diameter of the grip hoping that it might reduce the tension in my wrists when gripping the throttle all day (I have early signs of arthritis in the hands).
I really like them and have done the job I wanted. I expect they could be had at a cheaper price with a bit of research than the link I provided.
9Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 9:44 pm
Motorworks sell a Throttle Rocker pretty cheap and Foam grips like Gaz's Grip Puppies for only £8.50 ex vat
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=PA&SbCt=BA_15_40_PA_75
 Vibrations  Austra12    Fuel:  95 Octane
10Back to top Go down   Vibrations  Empty Re: Vibrations Wed Apr 27, 2016 11:08 pm
Chocolate
Chocolate
11Back to top Go down   Vibrations  Empty Re: Vibrations Thu Apr 28, 2016 9:36 pm
Ian Drinky
Ian Drinky
92KK 84WW Olaf wrote:There have been quite a few threads on vibrations.
Thanks Olaf,
i was thinking of fitting some bar risers as i do find that i lean forward a bit,
We spent a week driving around Ireland 2 years ago and wow what a great spot, i have a cousin that lives in Cork. chat soon Ian
12Back to top Go down   Vibrations  Empty Re: Vibrations Fri Apr 29, 2016 12:00 am
dark_gap
dark_gap
92KK 84WW Olaf wrote:That's the one!
I think if we obviate the bar end weights, cleaning completely the throttle mechanism and lubricating it with silicone spray ir will make the difference. Also we must remember only to clean and lubricate the mechanism, not the cable cause it has its own silicone cover...
If you find the answer please share with us! Very Happy
Similar topics
» Good Vibrations....
