1 1-4 non-firing still/again Sat Apr 16, 2016 10:43 pm
KJustin
Thought my problem was solved, but it's not. Quick recap: I have a new HES unit. Used (but known good) coils from a forum member. Also put in new spark plug leads.
After putting in the new HES, the bike fired right up on all cylinders. All seemed good. Didn't ride it then because it was late night. Took it out today. It started right up, running on all 4 cylinders. Rode down the street and had major backfiring and lurching/hesitation. Thought my timing was off so I moved the HES plate a bit counterclockwise (looking at the engine from the front) and took a ride. Same symptoms, lurching, backfiring. Though at full throttle as it approached redline it ran fine. Adjusted the HES the other direction (clockwise) and now I'm only firing on 2-3. Put the HES back to the original position and have the same no firing result on 1-4. Pulled plug 1 and have no spark and wet, unburned gas.
At the + input on both coils I get 11.2v with the key on and engine not running (my battery shows 12.5 or 12.6 in this state; headlight is on. With the engine running (on 2-3 only) I've gotten inconsistent readings. One time both + terminals were showing 7.2v. Another time both were showing 13v.
On coil 1-4 the - side always shows a low number, about 3.5. On the good, firing 2-3 coil the - side always reads what the + side reads. I also wired up an LED to attach to the +/- at the coils. Both coils show a pulsing light. Further, I have my tachometer sensor wound around cylinder 1 plug lead and I get tachometer readings.
Also have swapped the plugs around and the 1-4 plugs worked in 2-3. So the plugs are good.
At a loss here. What do I do next?
