2 Re: Turning ignition on. Which lights should start up? Wed May 05 2010, 15:47
reg_K100RS
Looks pretty normal to me Vudis.
I assume you have the choke/fast idle lever on?
The temp light only comes on when the motor overheats.
A bit bloody late if you ask me, that why I fitted a temp gauge
3 Re: Turning ignition on. Which lights should start up? Wed May 05 2010, 15:50
Vudis
Was it hard to fit? I'm thinking about the same thing... I have one temp gauge from An-26 airplane Guess it should fit. Besides, it won't clash with the panel
4 Re: Turning ignition on. Which lights should start up? Wed May 05 2010, 15:56
reg_K100RS
Pretty easy
i got my gauges from Ebay
I had to buy a sender from the dealer and thats about £12 I think
you can buy a harness to fit the temp and fuel gauges from Motobins
but I just made my own
I see the wiring info in the download section
5 Re: Turning ignition on. Which lights should start up? Wed May 05 2010, 16:00
Vudis
Thanks reg_K100RS. I'll try.
I dismantled the panel, but the light bulb, though seemed okay, was installed new, not the chinese bulb, but the genuine Osram... The same is with the oil pressure bulb...
6 Re: Turning ignition on. Which lights should start up? Sun May 09 2010, 05:43
ReneZ
Your lights are OK. The coolingwater temp light only comes on when the bike is getting too warm and the fan did not come on or gives too little additional cooling.
Greetings from
Rene
BMW K100 - 1985 (0030029) Scotland
K100-forum.com » Technical, repair and troubleshooting » Electrical » Turning ignition on. Which lights should start up?
Similar topics
