1 Fuse 2 blowing Mon Apr 18, 2016 5:55 pm
Just a minor niggle, but one that I could use some advice on. I'm blowing a fuse!
A little background first, during my week down under, Rosskko generously lent me one of his Kollection (naked 1986 RT) so that I could get out and ride and enjoy some of the wonderful roads and Kompany hereabouts in New South Wales.
Over the weekend, I was alerted to the fact that my tail light was not working and it was quickly discovered that the bulb was good but that No.2 fuse (7.5A) was blown. The bulb monitoring unit appears to be working correctly at start up, with the warning light clearing as soon as both brakes are operated and it was not detecting any faults with the tail light. The fuse was replaced and all appeared good, with the tail light (and brake lights) fully functional. The following day, as we continued the ride, Gaz noticed that my tail light was out again - we're not sure when it stopped working though. Quick check and Fuse No.2 had blown again. Rapidly depleting Gaz's supply of spare 7.5A fuses (the servo we stopped off at to avoid a monsoon didn't have any packs of fuses amongst their random selection of auto parts), the fuse was replaced and the tail light was working again.
When I parked up near my hotel in Sydney late on Sunday afternoon , I noted that the tail light was still working. However, when I went to take the bike out for a spin (after work) on Monday, as soon as I turned on the ignition and lights - no tail light and fuse 2 had blown again. As a precaution, in case there were any strange voltage spikes, I ensured that the lights were switched off before starting the bike (I know that the load shed relay should cut the power to the lights anyway) and only switched them on once the bike was running. The (non standard K100) headlights and brake lights continue to work perfectly - it's just the tail light that goes. As it was still day light, I headed off on a planned run to West Head and managed to pick up a pack of spare fuses from a servo on the way. As the fuse pack did not have a 7.5A fuse, I inserted a 10A fuse and all good again, tail light working as it should. I rode back in the dark via Palm and Manly beaches, checking every now an again that I still had a tail light. Got back to the hotel and, bugger! No tail light again, 10A fuse blown. I have no idea when it actually went - somewhere between Manly and Sydney CBD. Incidentally, the speedo also stopped working during this short return leg - thank goodness for GPS speedo for keeping me honest. I think that is unconnected with the tail light issue (all other fuses are good) and may be due to a loose instrument cluster plug - I need to do a little more investigation into that issue.
I've looked at the electrical schematics and can't see any other load on fuse no2 apart from the tail light. The bulb monitoring unit is not picking up the failure and I am perplexed as to why Fuse no. 2 keeps on blowing. The tail light bulb appears good and works when it has power - I suppose it is possible that it has a breakdown to earth somewhere but I can't determine when the earth occurs as it appears to be a random event.
Any suggestions?
Any suggestions?
Paul
"Gretel" K100LT 1989 (
"Donor" K100LT 1990 (Red) (VIN 0178091 Engine No. 4489 2024) - 6th & final owner (crash write-off now donor bike). June 2012 (73,000 miles) to November 2013 (89,500 miles)
