1 Light telltale malfunction? Wed Mar 30, 2016 3:59 pm
Bikesmith
Hi everyone!
Thank you all so much for your help with all of the issues on my 1985 K100rs.
Here's the new issue: The rider's manual says that when I turn on the ignition and test both brakes the rear light telltale should start flashing. But mine just turns off. The manual says that indicates a fault, but all the lights are working perfectly. Is there something I'm missing? The manual is for a 94 and my bike is an 85. Does the telltale on an 85 work differently than a 94? Is there a problem with my bulb monitoring unit? If so, should I even care if all of the lights are working correctly?
Thanks!
Thanks!
Jon
Mechanically competent, electrically perplexed
1985 BMW K100RS
1959 BMW R60
1942 Chevrolet 3/4-ton Special
1940 Royal Enfield WD/CO
1975 Porsche 911S
