1Back to top Go down   Vacuum Cleaner Empty Vacuum Cleaner Wed Mar 30, 2016 5:14 am
Now that I’m retired, I seem to sit around the house all day.
My wife said, “You could do something useful, like vacuum the house once a week.”
I gave it a moment’s thought and said, “Sure why not?  Show me to the vacuum.”
Half an hour later I walked into the kitchen for coffee.
The wife said, “I didn't hear the vacuum work, I thought you were using it.”
Exasperated, I replied, “The stupid thing is broken, it won’t start.  We’ll have to buy a new one!”
“Really,” she said, “Show me – it worked fine the last time.”
Having taken a video of the damned thing, I showed her.
2Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 5:22 am
crikey rosskko .....you must be bored ....
groan
3Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 5:22 am
Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271
Nice one!
Vacuum Cleaner Uk-log10 Vacuum Cleaner Sco-lo15
                              Paul  Vacuum Cleaner 905546712
4Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 5:45 am
k-rider
k-rider
put a k-engine on it, then she will hear it running all the time  (o) (o) (o)
k-rider
5Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 5:56 am
Do you think it might have a clogged filter ? Wink
Vacuum Cleaner Ir-log10
 ;BMW; K1200RS Red
6Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 11:44 am
She bought the electric start model instead of the kick starter.  Vacuum Cleaner 161205
Have you checked the battery?  Vacuum Cleaner 652573
7Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 12:22 pm
Born Again Eccentric wrote:Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271 Vacuum Cleaner 44271
Nice one!
+1 +1 Vacuum Cleaner 44271
8Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Wed Mar 30, 2016 1:26 pm
Chocolate
Chocolate
I think The issue is, he isn't using the Kickstarter!
So do this:
If you use the compression lever to get the indicator squared up you might miss the compression stroke. Here is my procedure. It works every time—and works on any thumper that I have ridden. Unfold the kick start lever and start kicking. Kick until you cannot kick anymore (should only be one or two strokes) Once you cannot kick anymore you know you are on compression. Bring the kick start lever all the way back up. Depress the compression release and hold it open until you bring the kick start lever back down just a quarter more--this varies, but a quarter is pretty standard. Let go of the compression release, bring the kick start lever back all the way up, and then give it a sharp kick. No gas should be necessary. Should fire right up. I don’t even use that indicator but I have noticed that the mark will come into the window using this procedure. Hope that helps.
9Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Thu Mar 31, 2016 5:23 am
Trueth be told he simply should have bought a Victa. Zip starts work on them
10Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Thu Mar 31, 2016 5:34 am
Time for tech upgrade. iRobot is the answer.
11Back to top Go down   Vacuum Cleaner Empty Re: Vacuum Cleaner Thu Mar 31, 2016 12:10 pm
When the K100 first arrived on the scene back in the dark days of the early '80s, at rallies when they'd turn up the noise reminded me of a vacuum cleaner........with a head cold.
