ALEX PITON
ALEX PITON
hi all after a good ride at the roll the dice rally at warwick last week end, i discovers my diff was leaking,
its either the crown wheel seal or the large o-ring, dose any one know he sizes for these...
thanks alex ..................... 1986 k100rs
Crown gear seal is 85x110x10mm
Shaft seal is 35x47x7mm
hi all dose any 1 know the dimentions of the diff seals Frog15hi all dose any 1 know the dimentions of the diff seals Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
ALEX PITON
ALEX PITON
thank you
ALEX PITON
ALEX PITON
do u happen to know the dimentions of the o ring betwine the 2 diff housing, cheers
171.1mm x 2.62mm
ALEX PITON
ALEX PITON
thanks heaps
ALEX PITON
ALEX PITON
that 171.1 would be Inside Diameter ??
ALEX PITON
ALEX PITON
hi guys just letting u know at the loacal engineers i picked up the o-ring no worries and the crown wheel seal was not able to be got in the exact dimentions but 85x110x12 was readly availble and fitted a treat. obviosuly tapped it in flush to the shim not to the case. i got 2 o-rings and the seal for $30 aud
